- Platform information:
- OS: Synology
- openHAB version: 2.5
Hardware related:
- Z-wave stick serial controller
- Z-wave Motion sensor
- Z-wave Dimmer
Goal
When I light up the light with the dimmer or the motion controller, stay on for 60 seconds unless I close the light manually or the motion detector still see me.
Tools
Timer, reschedule, if, loginfo, design pattern.
Problem
With the motion detector it works almost always but some motion detectors doesn’t want to be trigged on again after the 60 seconds.
When I put the light on manually, no timer is started and I don’t see any log saying the dimmer has changed state so I suspect this is why it doesn’t work. I only see the Z-wave stick had some movement.
My items name are long and I see people having short easy to read name, where do I do that? (“zwave_device_129fb235_node18_switch_dimmer” could just be “Shop_Dimmer”).
Rule code
var Timer StairTimer = null
rule "Stair light Motion"
Item zwave_device_129fb235_node20_alarm_motion changed from OFF to ON
if(StairTimer === null || StairTimer.hasTerminated()) {
logInfo('test', " Stair motion detected; switching Stair light to on")
zwave_device_129fb235_node18_switch_dimmer.sendCommand(100)
else {
StairTimer.reschedule(now.plusSeconds(60))
logInfo('test', " Stair timer restarted by motion detector")
rule "Stair light Timer"
Item zwave_device_129fb235_node18_switch_dimmer changed
if (zwave_device_129fb235_node18_switch_dimmer.state > (0) && StairTimer !== null) {
logInfo('test', " Stair timer restarted by switch > 0")
if (zwave_device_129fb235_node18_switch_dimmer.state == (0)) {
StairTimer = null
logInfo('test', " Stair timer cancelled by switch = 0")
if (zwave_device_129fb235_node18_switch_dimmer.state > (0) && StairTimer === null) {
logInfo('test', " Stair timer started")
StairTimer = createTimer(now.plusSeconds(60), [|
zwave_device_129fb235_node18_switch_dimmer.sendCommand(0)
logInfo('test', " Stair timer to zero, closing light")
StairTimer = null
logInfo('test', " Stair timer cancelled by expiration")
Log
19:54:33.990 [INFO ] [smarthome.event.ItemStateChangedEvent] -
wave_serial_zstick_129fb235_serial_sof changed from 179258 to 179259
19:54:34.541 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179259 to 179260
19:54:34.562 [INFO ] [g.eclipse.smarthome.model.script.test] - Stair motion detected; switching Stair light to on
19:54:34.565 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_129fb235_node20_alarm_motion changed from OFF to ON
19:54:34.592 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_device_129fb235_node18_switch_dimmer' received command 100
19:54:34.630 [INFO ] [arthome.event.ItemStatePredictedEvent] - zwave_device_129fb235_node18_switch_dimmer predicted to become 100
19:54:34.650 [INFO ] [g.eclipse.smarthome.model.script.test] - Stair timer started
19:54:34.651 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_129fb235_node18_switch_dimmer changed from 0 to 100
19:54:34.686 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_ack changed from 30677 to 30678
19:54:34.701 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179260 to 179261
19:54:35.000 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179261 to 179262
19:54:58.477 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179262 to 179263
19:54:59.013 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179263 to 179264
19:54:59.033 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_129fb235_node20_alarm_motion changed from ON to OFF
19:55:07.941 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179264 to 179265
19:55:07.961 [INFO ] [smarthome.event.ItemStateChangedEvent] -
19:55:08.498 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179265 to 179266
19:55:09.509 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179266 to 179267
19:55:09.802 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179267 to 179268
19:55:09.818 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_device_129fb235_node20_sensor_luminance changed from 0 to 2
19:55:10.433 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_129fb235_serial_sof changed from 179268 to 179269
Thanks!
Robin
