After yesterdays update the pushover command generates the following error. I couldn’t find any messages about any changes, so what happend?
regards Wolf
var action = actions.thingActions("pushover", "pushover:pushover-account:xxx");
action.sendMessage('Test', 'Openhab');
2022-09-18 13:52:03.996 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'JavaScript_Pushover' failed: org.graalvm.polyglot.PolyglotException: TypeError: (intermediate value).thingActions is not a function
All other ECMA 2021 scripts are running fine. The last update was about two weeks ago and the pushover scripts worked fine since one week, where I changed from DSL to javascript.
I copied the project to another sd card (just things and items, no bindings from jsondb folder) and run it on a separate raspi. Starting with the Pushover binding showed that the javascript script did the job. So I installed binding by binding and the script was still ok. Until the „System Info binding“ crashed the whole script. So it seems, that this binding has some bugs.
I changed the headline
