System:shutdown - Results in some errors
shutting down OH2 via Karaf result in some errors:
In my opinion this is because i linked the Items manuell in my default.items file.
18:20:33.855 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'max:thermostat:MKF0071697:MKF0048314': java.lang.IllegalStateException: Could not update status, because callback is missing
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Could not update status, because callback is missing
	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:179)
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:72)
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:56)
	at org.eclipse.smarthome.core.thing.internal.ThingManager.disposeHandler(ThingManager.java:738)
	at org.eclipse.smarthome.core.thing.internal.ThingManager.handlerRemoved(ThingManager.java:340)
	at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:122)
	at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:1)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:967)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:909)[org.osgi.core-6.0.0.jar:]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.unregisterHandler(BaseThingHandlerFactory.java:105)
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.deactivate(BaseThingHandlerFactory.java:74)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
	at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
	at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:783)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:757)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:550)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:725)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:530)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:414)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.Activator.access$300(Activator.java:53)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:273)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:290)[29:org.apache.felix.scr:2.0.2]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
	at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:312)[29:org.apache.felix.scr:2.0.2]
	at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:186)[29:org.apache.felix.scr:2.0.2]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.Module.doStop(Module.java:624)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1623)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1542)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:248)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:145)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.Module.doStop(Module.java:626)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.lang.IllegalStateException: Could not update status, because callback is missing
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateStatus(BaseThingHandler.java:307)[95:org.eclipse.smarthome.core.thing:0.8.0.201604051458]
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateStatus(BaseThingHandler.java:334)[95:org.eclipse.smarthome.core.thing:0.8.0.201604051458]
	at org.openhab.binding.max.internal.handler.MaxDevicesHandler.dispose(MaxDevicesHandler.java:142)[153:org.openhab.binding.max:2.0.0.201603310102]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$10.call(ThingManager.java:741)[95:org.eclipse.smarthome.core.thing:0.8.0.201604051458]
	at org.eclipse.smarthome.core.thing.internal.ThingManager$10.call(ThingManager.java:1)[95:org.eclipse.smarthome.core.thing:0.8.0.201604051458]
	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:170)[89:org.eclipse.smarthome.core:0.8.0.201604051458]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
	... 1 more
At the end i get this. Did not count, but i think that this is exactly the number of Items i have.
If this isn’t really an error, is there a way to disable that message?
18:20:38.433 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.434 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.435 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.436 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.438 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.439 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.440 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.442 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.443 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.444 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.445 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.447 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.449 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.450 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.451 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.453 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.454 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.455 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.457 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.458 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.459 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.460 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.461 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.462 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.463 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
18:20:38.464 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemThingLinkRemovedEvent'.
That’s indeed both not nice (although it does not harm).
As both is within ESH code, may I ask you to enter two issues at https://github.com/eclipse/smarthome/issues?
Sure… Did it! I’ll hope the way i did it is ok.
