I have this rule and it does not seem to work.
rule "CT100 Cleanup"
System shuts down
sendCommand(HVAC_Fan_Mode, 0)
I have System started rules that work…
Tom
System shuts down
Tom
Please set up a logging for that
logInfo("Shutdown","Rule triggered")
to see, if the rule gets triggered at all.
It’s possible that there is no chance to do a sendCommand here, because of the asynchronous design, so it could be that the bindings are shut down before the rule will fire up at all.
The device is a ZWave thermostat I see nothing in the log
System shuts down
logInfo("Shutdown", "Shutting down, Turn Fan OFF (Auto)")
I tried another shutdown rule
Item has no external I/O
rule "Sprinklers System Stop"
System shuts down
logInfo("Shutdown", "Shutting down, Init Sprinklers")
//Zone_Time.postUpdate(30)
Zone_Time.sendCommand(30)
item:
Number Zone_Time “Next Watering time [%d]” (gRAIN)
Neither one runs or enters a log entry
tom
I guess that is an issue, definitely at least a log should work…
Hey,
DId you find any solution regarding how to use System shutdown ?
My current rule has the same syntax and works file.
I am not sure what the issue was.
Tom
