fyi @cweitkamp
I was finally able to resolve this issue for my installation. This pointed me in the proper direction. Apparently a few thing definitions for zwave things had been changed leading to a re-read of my rules file every time one of them received an update. Per design this triggered the āsystem startedā rule. Due to the size of the rules file this took around 25-30 seconds, slowing down the system and making it difficult to correlate cause and effect. After deleting and rediscovering all zwave things the frequent system started triggers subsided and everything again works like a charm.
Nice to hear. In my config there is no zwave however
Itās possible that one of the bindings you use had an updated Thing definition, which would need to be updated for existing Things just as the zwave Things are (delete and rediscover/recreate).
and that makes me wonder, @stefaanbolle how are your things defined? Are your things defined in Paper UI or text files? Sorry if I missed that info somewhere in previous post
That is probably still the case in my system. When restarting the system I still get 4 or 5 system started triggers, instead of a single one under 2.4. Those are obviously not triggered by zwave things any more, so there must be another binding causing the trouble. Will have to go through the release notes once more and maybe update those other things as well.
Out of interest: would defining things via text files make for automatic updating of things after changes to thing definitions? My things are all defined in Paper UI but it might be worth the trouble switching to text files if there is a benefit to it.
No, there is still no mechanism to update Thing definitions (see post 19). With non-managed Things, you need to remove the Thing files and then add them again to update the Thing definition. For zwave, you also canāt update your configuration parameters if using non-managed Things.
People claim it is better to use non-managed Things, since they can edit the files. But managed Things are stored in the JSONDB, which are files that can also be backed-up, edited, etc. There is no benefit at all and it is much more error-prone, so best to use managed Things.
I agree Scott but what Iām wondering and why I asked stefaanbolle is because say thisā¦ a user uses a binding with a text file thing configuration and upgrades and the thing definition has changed and the text file thing is now incorrect. Could this possibly be what causes the problem with system started triggering repeatly
@mstormi put together a list of issues people have found in 2.5ā¦
Thing definitions are a new angle on the issue. I would think incorrect manual Thing configuration could also cause issues, but I would expect that there would be errors from validation or the binding, if the configuration of a Thing in a .things
file was incorrect. It may cause the startup issue too.
Thanks for the explanation! Still it seems much more appealing to me to remove and re-add my thing definition files than deleting and rediscovering all zwave things via Paper UI. After all, with no changes to the core planned until 3.0 I expect this problem to appear each time I upgrade the addons. I guess I will have a look into how to define things in text files and then decide which one is the lesser of two evils.
I stumbled upon your rule for automatic rediscovery as well, but didnāt dare to use it for fear of not being able to troubleshoot it if anything went wrong . All this is still a little bit over my head.
Hi, Iām suffering this issue since 2.5.0, and had to rollback to 2.4.0 that is more than stable for me. Now thanks to this thread I decided to give a try to 2.5.2-1 and managed to delete and re-add some z-wave items and it is better now as it only fires āSystem restartedā a bunch of times around 2:30 am, the rest of the day it is fine (before it was restarting every few minutes all around the day in a quite random way)
But still some of the items I deleted and re-discovered continue generating the āThing updatedā message (always with messages stating that the item value changed from NULL to something) and then a System started
2020-03-21 02:36:48.266 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node5_blinds_control changed from NULL to 100
2020-03-21 02:36:48.282 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:c464a06d:node5' has been updated.
2020-03-21 02:36:49.673 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:c464a06d:node6' has been updated.
2020-03-21 02:36:49.710 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node10_switch_dimmer1 changed from NULL to 0
2020-03-21 02:36:49.719 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:c464a06d:node10' has been updated.
2020-03-21 02:36:49.800 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_kwh changed from NULL to 15.49
2020-03-21 02:36:49.813 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_watts changed from NULL to 0.8
2020-03-21 02:36:49.839 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_scene_number changed from NULL to 2.0
2020-03-21 02:36:49.864 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_switch_binary1 changed from NULL to OFF
2020-03-21 02:36:49.877 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_kwh1 changed from NULL to 15.49
2020-03-21 02:36:49.889 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_watts1 changed from NULL to 0.8
2020-03-21 02:36:49.900 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_switch_binary2 changed from NULL to OFF
2020-03-21 02:36:49.913 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_kwh2 changed from NULL to 45.4
2020-03-21 02:36:49.925 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node11_meter_watts2 changed from NULL to 0
2020-03-21 02:36:49.930 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:c464a06d:node11' has been updated.
2020-03-21 02:36:56.349 [vent.ItemStateChangedEvent] - zwave_device_c464a06d_node10_switch_dimmer1 changed from NULL to 0
2020-03-21 02:36:56.364 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:c464a06d:node10' has been updated.
I tried to clear cache, restarting several times, but nothing
Itās a known (but unfixed) bug that updates to things can cause rule reloads (resulting in system started
rules being executed).
Ok, thanks for the confirmation! I hope it is fixed soon. It must be something else too, because those items always updates from NULL to something, so it is like they donāt store the new value for any reason
The āsomething elseā is why is the Thing updating anyway? This is like a config property change, not a status (online/offline) change.
Well I have to correct myself: it isnāt a bug. Itās a to be expected side effect that in theory has been there all the time. Which means you cannot hope for this to simply get fixed soon or at all. Sorry.
But devs are aware of it and that it recently aggravated and are busy thinking what can be done about it.
I have the same problem just now and I was happy to find this older topic.
Thanks to this thread, I was able to trace the error back to the Zwave devices. But it is strange that the error only occurs now after I have freshly installed OH2.5. Before that, OH2.5 ran flawlessly for months!
Now Iām confused. Why didnāt I have any problems with OH2.5 before? Obviously Iām too stupid to find the solution in this thread.
I deleted and rediscovered all Zwave devices. Without success. I would be very happy and grateful if someone could help me!
AppleJack
