- Platform information:
- Hardware: Hyper-V
- OS: Ubuntu 16.04
- Java Runtime Environment: 1.8.0_151-b12
- openHAB version: openHAB 2.2.0 Build #1072
I have a rule:
rule "System started"
System started
logInfo("RULE.SystemStarted","<-- System Started")
Why when starting OpenHAB, it works several times?
2017-11-01 08:59:02.316 [INFO ] [egram.internal.TelegramActionService] - Bot bot1 loaded from config file
2017-11-01 08:59:02.789 [INFO ] [voicerss.internal.VoiceRSSTTSService] - Using VoiceRSS cache folder /var/lib/openhab2/voicerss/cache
2017-11-01 08:59:10.401 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = b5633553-b5ca-442e-ab89-0a9004b1719e, base URL = http://localhost:8080)
2017-11-01 08:59:18.888 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'connectsdk.items'
2017-11-01 08:59:19.054 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'co2.items'
2017-11-01 08:59:19.106 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'gateway.items'
2017-11-01 08:59:19.182 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'router.items'
2017-11-01 08:59:19.236 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'bell.items'
2017-11-01 08:59:19.334 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2017-11-01 08:59:19.606 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hiaomi.items'
2017-11-01 08:59:19.879 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'network.items'
2017-11-01 08:59:19.989 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'climate.items'
2017-11-01 08:59:20.100 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'monitor.items'
2017-11-01 08:59:20.120 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'audio.items'
2017-11-01 08:59:20.160 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.items'
2017-11-01 08:59:20.222 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'milight.items'
2017-11-01 08:59:20.414 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonoff.items'
2017-11-01 08:59:21.561 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2017-11-01 08:59:32.753 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonoff.rules'
2017-11-01 08:59:33.319 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'audio.rules'
2017-11-01 08:59:34.074 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'group.rules'
2017-11-01 08:59:35.697 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'climate.rules'
2017-11-01 08:59:40.404 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hiaomi.rules'
2017-11-01 08:59:40.862 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.rules'
2017-11-01 08:59:40.926 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lightbox.rules'
2017-11-01 08:59:41.463 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'co2.rules'
2017-11-01 08:59:41.772 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'network.rules'
2017-11-01 08:59:42.356 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'update.rules'
2017-11-01 08:59:42.502 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'start.rules'
2017-11-01 08:59:43.463 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'garage.sitemap'
2017-11-01 08:59:43.529 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'telefon.sitemap'
2017-11-01 08:59:44.303 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'milight.things'
2017-11-01 08:59:44.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'network.things'
2017-11-01 08:59:44.882 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2017-11-01 08:59:45.579 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2017-11-01 08:59:46.328 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-11-01 08:59:46.362 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-11-01 08:59:48.506 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.215.111:8080
2017-11-01 08:59:48.508 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.215.111:8443
2017-11-01 08:59:48.849 [INFO ] [thome.model.lsp.internal.ModelServer] - Language Server started on port 5007
2017-11-01 08:59:49.012 [INFO ] [home.model.script.RULE.SystemStarted] - <-- System Started
2017-11-01 08:59:49.764 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-11-01 08:59:50.101 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-11-01 08:59:51.759 [INFO ] [b.core.service.AbstractActiveService] - Expire Refresh Service has been started
2017-11-01 08:59:52.052 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-11-01 08:59:52.061 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqtt-loc'
2017-11-01 08:59:53.027 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqtt-net'
2017-11-01 08:59:53.348 [INFO ] [e.smarthome.model.script.RULE.CO2Box] - <-- CO2 - 581.68
2017-11-01 08:59:53.356 [INFO ] [.smarthome.model.script.RULE.CO2Room] - <-- CO2 - 500.33
2017-11-01 08:59:55.271 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-11-01 09:00:03.469 [INFO ] [home.model.script.RULE.SystemStarted] - <-- System Started
2017-11-01 09:00:10.355 [INFO ] [home.model.script.RULE.SystemStarted] - <-- System Started
