All,
Platform information:
Hardware: Raspi 3
OS: openhabian 1.4 running
Java Runtime openjdk version "1.8.0_152"
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
openHAB version: OH 2.3 stable
Issue of the topic: out of a sudden Warning appear and ERRORS followed by unresponsive tool (habin, PaperUI, karaf)
Please post configurations (if applicable): Don’t know where to start
Items configuration related to the issue - no obvious items involved
Sitemap configuration related to the issue - no sitemaps in use (habpanel only)
Rules code related to the issue - no obvious rules involved
Services configuration related to the issue - no obvious bindings involved
once more I did a restart of the system (not learning from my mistakes obviously) and get loads of these Warnings:
2018-09-17 18:50:54.729 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@59890e' takes more than 5000ms.
I am actually lost to find out what I need to look for seeing “59890e” in the logs.
Habpanel is not accessible - neither is Paper UI.
Login into karaf does not work, but OH is obviously running somehow (log entries are generated and
openhab2 status
returns:
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Mo 2018-09-17 15:47:34 CEST; 3h 25min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 746 (java)
CGroup: /system.slice/openhab2.service
└─746 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.d...
Sep 17 16:41:04 Homer karaf[746]: at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:367)
Sep 17 16:41:04 Homer karaf[746]: at org.glassfish.jersey.server.ChunkedOutput.flushQueue(ChunkedOutput.java:190)
Sep 17 16:41:04 Homer karaf[746]: at org.glassfish.jersey.server.ChunkedOutput.write(ChunkedOutput.java:180)
Sep 17 16:41:04 Homer karaf[746]: at org.eclipse.smarthome.io.rest.sse.internal.SseEventOutput.write(SseEventOutput.java:46)
Sep 17 16:41:04 Homer karaf[746]: at org.eclipse.smarthome.io.rest.sse.internal.SseEventOutput.write(SseEventOutput.java:1)
Sep 17 17:06:30 Homer karaf[746]: Exception in thread "pool-27-thread-3" java.lang.OutOfMemoryError: Java heap space
Sep 17 17:32:26 Homer karaf[746]: Exception in thread "pool-27-thread-4" java.lang.OutOfMemoryError: Java heap space
Sep 17 18:07:05 Homer karaf[746]: Exception in thread "ESH-OSGiEventManager" java.lang.OutOfMemoryError: Java heap space
Sep 17 19:00:42 Homer karaf[746]: Exception in thread "pool-27-thread-5" java.lang.OutOfMemoryError: Java heap space
Sep 17 19:01:08 Homer karaf[746]: Exception in thread "Timer-3" java.lang.OutOfMemoryError: Java heap space
even a shutdown, deleting cache/* and tmp/* did not do the trick…
after removing all rules, mainly zwave warnings were logged:
2018-09-17 19:29:36.183 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 9: Already processed another send data request for this callback Id, ignoring.
2018-09-17 19:29:46.147 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - Receive queue TIMEOUT:
2018-09-17 19:30:19.663 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 9: Already processed another send data request for this callback Id, ignoring.
2018-09-17 19:31:05.928 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - Receive queue TIMEOUT:
2018-09-17 19:31:13.047 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 9: Already processed another send data request for this callback Id, ignoring.
2018-09-17 19:31:13.078 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - Receive queue TIMEOUT:
Anyone, who could give me a hint?
