I am using openhab2 2.5.11 on my RasPi 4.
Using Paper UI I installed the SystemInfo binding, and added the corresponding Thing.
I want to change the priority of the CPU uptime channel from medium to high.
When I look at the configuration of the Thing, I only see the “Name” channel under CPU:
I should mention that my eventual goal is to change the uptime channel to priority=High.
I tried to do that via a *.things file, but it didn’t work
If someone had a working example of changing the uptime channel to High priority, that would also satisfy my need.
Not all channels are listed by default. Uptime is afaik one of them.
At the top of the channels list there should be a “show more” checkbox.If you click it, your channel should appear
