JoeRu
(Johannes Rumpf)
December 20, 2021, 4:46pm
1
I cleared the cache and restarted docker more than once.
A migration back to 3.1.0 results in the same error.
[ERROR] [t.core.internal.addons.AddonResource] - Exception while installing add-on: null
suggestions?
JoeRu
(Johannes Rumpf)
December 20, 2021, 8:59pm
2
disabling remote-add on management and switching back on results in this error message
2021-12-20 21:57:30.636 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-knx': Error:
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.knx/3.1.1
rossko57
(Rossko57)
December 21, 2021, 12:26am
3
Where did you start from? This might be relevant -
Dear all,
We have today published the openHAB patch release 3.0.2. It brings a couple of bug fixes for our stable release. You can find the details in the release notes .
Even if you might not need these fixes for your setup, we highly recommend to install this patch, since it takes care of adapting the update and download mechanisms to no longer point to Bintray, but to Artifactory. This is necessary, since Bintray services shut down on May 1st, 2021 , which means that add-ons cannot be dynamic…
JoeRu
(Johannes Rumpf)
December 21, 2021, 6:56am
5
i cleared the issue - it was a java-options problem. Until now - it seems like these options i had put in for some reasons i do not remember does now “work”
-Dhttp.proxySet=true -Dhttp.proxyHost=192.168.176.125 -Dhttp.proxyPort=443 -Dhttp.nonProxyHosts=192.168.176.*|127.0.0.1
Removing them solved the problem.
