For over a week now, my Tado binding doesn’t update the temperature and humidity values anymore.
I run OpenHAB 4.3.5. What I tried up to now:
- Disable/Enable the Tado Home / Bridge thing
- Restart OpenHAB
- Uninstall and Re-Install the Tado Binding.
This is what I get when I try to re-authorise with Tado with the URL http://my-OpenHAB-IP:8089/tado : Status: OAuthClientService errornull
After some research, I’ve found the following entries in the log which might give a hint.
| 17:05:26.105 | DEBUG | org.openhab.binding.tado.internal.handler.TadoHandlerFactory | getAccessTokenResponse() error null |
| 17:06:16.710 | DEBUG | org.openhab.binding.tado.internal.auth.OAuthorizerV2 | addAuthorization() => getAccessTokenResponse() error: null |
| 17:06:16.740 | DEBUG | org.openhab.binding.tado.internal.handler.TadoHomeHandler | Error accessing tado server: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header |
Please help me to solve this issue - currently my whole setup with 5 thermostats is not working anymore with OpenHAB.
Btw., I do have the Tado premium subscription.
