Support for all zone types: Heating, AC, Hot Water
Item for mobile device HOME/AWAY status
Auto-discovery of zones and mobile devices after initial configuration of credentials
Changes via items are collected for a few seconds before they are sent to tado°. This allows you to do combined changes from the UI, for example change temperature and mode in one call.
Fills missing overlay parameters from current zone state, trying to keep them unchanged, if compatible with requested change
Uses termination condition preset as defined in the tado° app as fallback
The README provides more details. I hope you like it.
I’ve just tested it on the heating and it’s working, but I get the below:
2017-12-05 22:48:27.198 [WARN ] [okhttp3.OkHttpClient ] - A connection to https://my.tado.com/ was leaked. Did you forget to close a response body? To see where this was allocated, set the OkHttpClient logger level to FINE: Logger.getLogger(OkHttpClient.class.getName()).setLevel(Level.FINE);.
Thanks a lot for this work - I was waiting for a long time to see tado finally being integrated with a binding into openhab!
2017-12-08 11:38:06.597 [WARN ] [okhttp3.OkHttpClient ] - A connection to https://my.tado.com/ was leaked. Did you forget to close a response body? To see where this was allocated, set the OkHttpClient logger level to FINE: Logger.getLogger(OkHttpClient.class.getName()).setLevel(Level.FINE);
I come from the Tado solution Benjamin had created to this, so far looking good. I did have to make some trial and error testing in order to understand how to setup multiple heating zones, but got it. I ended with this
Things
Bridge tado:home:boni [ username="xxx@gmail.com", password="xxx" ] {
zone DRHeating [id=1]
zone LRHeating [id=2]
zone BRHeating [id=3]
Etc
mobiledevice phone1 [id=123456]
Item
Number DRTadoTemp "Tado dining temperature [%.1f °C]" <temperature> (gDR) { channel="tado:zone:boni:DRHeating:currentTemperature" }
Number LRTadoTemp "Tado living temperature [%.1f °C]" <temperature> (gLR) { channel="tado:zone:boni:LRHeating:currentTemperature" }
Etc.
hello i am using Tado binding since 4 days now. The only problem is that i am maintaining my server a lot recently and had to restart openhab service many times. It happened twice that the binding was no more installed at the next reboot
Thanks all for the feedback and for trying the binding.
@KurtS@AndersBN So far I couldn’t find a way to reliably reproduce the leak problem. I just see it from time to time in the logs. So if you know how to force it, please let me know.
@ThomDietrich At least at the moment, I’m not planning to submit it to openhab2-addons. The code should first prove to be stable and well tested by the community. Then I might consider it.
@Melkor I guess that comes from the Eclipse marketplace integration in OpenHAB. The documentation says:
“Attention: Please note that after a system upgrade the installed add-ons are lost and you will need to re-install them. This behavior will be changed in future.”
I have it nearly every 10 minutes. The binding works fine but the warnings are still there.
I found some links concerning this issue but I have no clue if it can help you @dfrommi
@PeterP Thank you so much for your help and the list of issues. Very interesting. However, I’m not directly using the OkHttp client, but instead a generated retrofit2 client that is internally using OkHttp.
But I’ve created a release now that is manually closing the connection after API calls and also in all error cases. I hope that is solving the issue.
@KurtS@AndersBN@PeterP Would you please be so kind and try release 0.9.1 and check if the leak-messages are gone? I’m still not able to reproduce it.
Thanks you very much.
2017-12-13 23:28:03.228 [WARN ] [com.squareup.okhttp.OkHttpClient ] - A connection to https://my.tado.com/ was leaked. Did you forget to close a response body?
I have one last idea where it could come from. The OAuth interceptor, that is taking care of access token and token refresh might be the culprit. Would be quite surprising, because it’s 100% swagger generated and I’m for sure not the first one using it, but worth a try.
Ok, one more time…
I could identify a potential leak in the OAuth interceptor. So guys, could you please one more time try the updated 0.9.1 release. I’m cautiously optimistic that it will solve the leak.
And thanks again very very much for your support and your patience.
how can I find out the mobile ID?
I registered my phone in my TADO app and it is also shown online, so home/away mode works.
but now I do not know which ID i have to take for my binding.
Your description / readme only writes: " It is again easiest to refer to discovery in order to find the id"
But where to get this id?
