I am installing openHAB, integrating my various pieces of equipment and I was wondering how to integrate my Tado° smart thermostat. I can see there are no binding for it (yet), and I don’t have the knowledge to develop one myself.
Does anyone has succeeded in integrating the Tado thermostat with openHAB ?
Or any other alternative such as replacing a thermostat by thermostatic valves + rules ?
Tado° seems to be very shy about providing public links to the API information (I just looked). If you used my.openHAB, you could integrate between openHAB and Tado° using IFTTT, but ideally they would offer up better information about their API publicly, aside from just a press release, so there could be an openHAB binding developed for it. If they send me a test unit and all the information, I might consider developing it myself! (I’m going to need a European thermostat for a split system heat pump in the next month or two).
thanks for your quick reply. I am actually using my.openhab but I excluded using IFTT: I don’t want to rely on yet another external provider and build my “home” automation on external services without any SLA. That said, Tado° API will certainly be a web API, not a local API, so the problem on relying on external services remains.
I will contact them and talk to them about supplying you with a test unit. I’ll keep you posted !
Thanks, Serge! Perhaps a Tado° binding would not be too different from the Nest and Ecobee ones I wrote earlier. They are both very good thermostats, but they were primarily designed with North American HVAC systems in mind. The Tado° might be just what I’m looking for, for a modern European heating system. Feel free to give them my email at john at cocula dot com. Thanks very much!
Good morning to all. I’m a newby in openhab, but I am a news that maybe can interest someone. I connected my TaDo thermostat (read only) with openhat with the next item:
