Hi
Can someone help me with a question about integrating google assistant with OpenHab.
What tag should I use to move up and down the rollershutters?
Right now there are only the ones i know:
[“Lighting”]
[“Switchable”]
[“CurrentTemperature”]
[“Thermostat”]
With the tag, [“Switchable”] rises 5cm and stops.
Some help?
I use [“Lighting”], with the wording “Rollershutter to 80%”, and the answer is “The lamp rollershutter is set to 80%”. If someone knows a better solution, please let us know
Has there been an update to Openhab’s Google Assistant tags to include Shutters / Garage door type so we can say “Open” and “Close” instead of on / off? I see that there is a specific Garage Door device type with OpenClose trait. https://developers.google.com/actions/smarthome/guides/garage
Unfortunatly not, for garagedoors. But for blinds/rollershutter open/closed works fine.
If you have a garagedoor which operate as a Dimmer type thing, then I would say you could get it to work. But if its a switch, it wont work.
The tag is [“Blinds”]
My Item type is Rollershutter (MQTT thing). When I tried [“Blinds”] as a tag, it shows up on Google Home as blinds, but I cannot control it, i.e. no open / close / up/ down/ stop etc. When I said “Hey Google, close the garage door”. It says “Sure, closing the Garage Door”. But nothing happened.
EDIT: never mind, looking at the log, I see it issued the 0 and 100 commands. I have updated my rule accordingly, and it now works.
Is it somehow possible to add the “Blinds” tag via PaperUI? I have “Blinds” in the Category field in the PaperUI item “editor”, but Google Home does not find those Rollershutters…
