i have installed the new component somfy izymo on/off, now the log shows:
Detected a new unsupported device: NetworkComponent
If you want to add the support, please create a new issue and attach the information below
Supported commands: { }
Device states:
{name=‘core:DeviceDefectState’, type=3, value=2,8,18}
{name=‘core:NeighboursAddressesState’, type=3, value=2,8,18}
sorry for answering so late, I have been away for a while.
Thank you for the provided log, apparently there are no commands associated with the NetworkComponet and the states do not return much…
I do not see any added value by supporting this device, since its channels would be rather useless.
I suggest ignoring these devices in the next binding versions, sorry
Ondrej
Concerning the EnOcean Window Handle: this is not that critical for me > i will try it with the EnOcean OH2 Binding.
But i am a little concerned about the stability of the Tahoma Binding. I am running multiple devices over the Tahoma Box and i have some troubles about the reliability.
I have 10 rollershutters and 4 zwave switches and I do not face any problems.
Sorry to hear you have troubles. I’ll prepare a solution for the “too many requests” issue, but I have no idea what to do with occasional “bad credentials error”
I have migrated the Tahoma binding to the newer API v2 (endUserAPI) which changes polling for changes and hopefully mitigates the “too many requests error”
Hi Ondrej,
Thanks for the update. Can you tell me/us where to find the most recent sources for this update? I would like to be able to debug in case of any strange behavior.
Unfortunately, the binding fails to connect, immediately after restart I see the following error:
2019-08-04 14:47:32.293 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Refreshing Tahoma states...
2019-08-04 14:47:32.294 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Doing relogin
2019-08-04 14:47:32.317 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Doing login
2019-08-04 14:47:32.373 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Cannot get login cookie!
java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:684) ~[?:?]
at org.openhab.binding.somfytahoma.internal.handler.SomfyTahomaBridgeHandler.login(SomfyTahomaBridgeHandler.java:150) ~[?:?]
I seem to have both your current version and the one merged into master in my system, but have no idea how to remove the builtin one:
openhab> bundle:list -u | grep somfy
192 x Active x 80 x 2.5.0.201908021953 x file:/openhab/addons/org.openhab.binding.somfytahoma-2.5.0-SNAPSHOT.jar
233 x Active x 80 x 2.5.0.M1 x mvn:org.openhab.binding/org.openhab.binding.somfytahoma/2.5.0.M1
Have you tried to uninstall the bundled one in PaperUI? Or command bundle:uninstall 233?
Only one should be active… (I have even newer version)
288 x Active x 80 x 2.5.0.201908030732 x file:/opt/openhab2/addons/org.openhab.binding.somfytahoma-2.5.0-SNAPSHOT.jar
I haven’t mentioned it, but the latest addon required OH2 restart since it uses the shared HttpClient optimization.
I managed to uninstall the bundled one via Paper UI and afterwards restart the new binding:
openhab> bundle:list -u | grep -i somfy
openhab> bundle:restart 192
But now, I am getting the Auth-Challenge exception again:
This time, I am sure that this is caused by the new implementation as this exception is thrown in SomfyTahomaBridgeHandler.java line 150 , which would be the reponse…send() in the new code.
And, which I forgot to write (), my items stay in the state INITIALIZING , even the ones I have created earlier with a things file.
I think it might be an issue with the shared http client.
Please, are you able to test this binding on a clean OH2.5M1 installation - not dockered one?
Just to create the bridge with your credentials …
i can confirm this behavior (items stays in state INITIALAZING)
The bridge (Thing) and one item (Gateway status) are online but no actor (e.g.) velux blinds and shutters)
thanks for feedback, apparently your bridge and gateway are initialized, so there’s no HTTP protocol violation like @hakan has. This is good.
The problem with other devices staying in INITIALIZING state might relate to performance of your OH2 installation.
Once the bridge is initialized, in the next 5 seconds the binding attempts for the first time to update other devices states (gateways and actiongroups are set to ONLINE instantly). If the bridge is not ONLINE yet (bridge becomes ONLINE once it is successfully logged in to Tahoma cloud) it is skipped and next attempt is in seconds defined by statusTimeout parameter.
I will definitely improve this, but can you confirm the value of statusTimeout configuration parameter (from a bridge thing) and check if the states get fixed after some time specified by this parameter?
in debug mode you can check the attempt of updating states by finding “Updating all states” message in openhab.log
or you can provide me your debug log, I can check the behaviour by myself.
Hi Ondrej,
thanks for your binding. I think I found an error
I have 4 Rollershutters and two window-motors…
Everything works fine, but when the windows are open and it begins to rain and the velux window clothes by it thelve, OH does not recognize it (i was waiting 30 minutes). Only if I open the tahoma app on my smartphone or if i control one of the other somfy things in OH, then also OH recognizes it.
Updating changed states triggered by external events is a known issue, but it works for the lastest SNAPSHOT and Tahoma box. This event is not provided as a common event and the binding regulary updates it by calling getStates command (the period is defined by the bridge’s configuration parameter stateTimeout)
I have a Tahoma.
I have the 2.4.0 Binding…
I now installed the 2.5.0 Snapshot binding, but I dont know how to get the tings and configuration of it.
Regards
