This was also true for OH 1.x, for what it is worth.
As Dim said, the default logging configuration will prevent this out of the box.
@Dim, thank you for your very clear answers. This is a great help.
@rlkoshak, thanks also for your additional clarifications.
Not sure how to mark this resolved - I saw a post somewhere else where that mark was added. In any case, all of my questions are answered, and very quickly as well. I appreciate your responsiveness.
I would like to suggest that the information in this posting be added to the documentation page below.
If no one objects, I will make a submission along with a PR sometime after mid-August.
Well, in this case because you responded to an existing thread rather than starting a new thread you don’t have that option. Neither answer is the solution to the original posting.
When you do start a new thread, you will have a little box with a checkmark below each response. You can press that for the solution to the problem in the original posting.
Given the changes that are in progress with logging (upgrading to Log4J 2) and the userdata folder (moving more stuff out), it might be better to wait. Though I know for a certainty any PR would be gladly accepted.
I’d like to extend the question regarding logging to remote logging. I already found out that the following addition to org.ops4j.pax.logging.cfg makes openhab log to a remote syslog host:
# Syslog appender
log4j.appender.syslog=org.apache.log4j.net.SyslogAppender
log4j.appender.syslog.layout=org.apache.log4j.PatternLayout
log4j.appender.syslog.layout.ConversionPattern=openhab2: %d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j.appender.syslog.syslogHost=<SyslogHost>
log4J.appender.syslog.facility=KARAF
log4j.appender.syslog.facilityPrinting=false
“syslog” has to be added to the log4j.rootlogger line to activate it.
The problem with this is that all multiline log lines (like tracebacks) are cut after the first \n.
Is there a solution for this? Will Log4J 2 bring any improvements in this department?
While we are at it, I’ve posted aa solution on how to send the logs to a Logstash/Elasticsearch server here:
@Dim, thanks for very specific information about maxFileSize and maxBackupIndex. Where are these variables set? Also, maxFileSize is clear. Is maxBackupIndex the maximum number of backup files kept? Once the maxBackupIndex number is reached, the oldest file is deleted? Just collecting information for a contribution to the documentation.
@otherCommenters, all good information, and probably need a single article collecting all the information here and other places about logging overall. That said, I think it is important to add a section about default logging rollover policy in the installation documentation so sysadmins such as myself don’t freak out worrying about systems falling over in the middle of the night because of full disks. I am still on vacation, but I hope to put together a short contribution when I get back.
/var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
New log4j2 example here: Log4j2 Sample Config
20-200% performance improvement with the new RollingRandomAccessFileAppender !
Source: https://logging.apache.org/log4j/2.0/performance.html#whichAppender
Speaking of Karaf 4.1.x and the new log4j2: with my old 2.2 snapshot that was around #995ish i could filter log output on the console like this
log:tail | grep -v somestring
After upgrading to #1010 the grep -v part of the commandline is ignored. Is this a known new feature?
I am currently setting up my logging preferences and would like to log detailed (DEBUG level) infos to a file while only displaying INFO level stuff in the console. Is that possible somehow?
I tried something like this:
log4j.logger.org.openhab.binding.mysensors = INFO, osgi:*
log4j.logger.org.openhab.binding.mysensors = DEBUG, mysensors:*
where the mysensors binding is what I want to log and ‘mysensors’ is a file logger I created. I am getting an error message though.
Also what does the :* do? I copied that one from the demo rules.
Hi All,
looking into “my” configuration of the logging, all entries start with log4j2 instead of log4j?
To make use of these suggestions above, can I just change this, or what’s the story.
Sorry - but I am confused.
BTW: I am using the 2.2 Snapshot
Michael
As @Dim mentioned above, the latest snapshot now uses the new log4j2. The configuration files are different and you should read the official documentation linked above.
See also:
Since my problem is related to logging i append it here.
Isn’t it possible to handle the log files with logrotate anymore? I have the following set up:
/etc/logrotate.d/openhab
/var/log/openhab2/openhab.log {
rotate 6
daily
nocompress
missingok
copytruncate
problem is the copytruncate. When a logrotate is done the new logfile is as big as the old one (and messed up) and new logs are appended. In notepad++ it looks like this:
How can i solve this? Thanks
P.S.:I am on the latest snapshot.
You do realize that openHAB rotates its own log files right? I’m not sure what would happen if you tried to rotate the log out from under it but I would not expect it to work, as you are seeing. Is there something wrong with letting OH do it for you?
Thats right, but i prefer having a logfile for each day instead of a 10mb file. I didn’t find a way to implement that in the OH2 logging system.
It worked before but it seems to have stopped a few days/weeks ago.
Are you on an SD card? If so I’m willing to bet real money your SD card is failing. I discovered I had a failing SD card when logrotate stopped working and my syslog filled up the whole file system.
Yes i am on a SDcard. Do you have some advise on how to find out if it is really failing? Maybe a an app that tests the card?
No advice needed. If log rotate worked for awhile and doesn’t anymore your SD card is failing. End of story. Backup what you can NOW. Verify the files are not corrupted (most likely they are not), and switch out to a new SD card.
Hi!
Just upgraded to 2.2.0 #1066 and I cannot get separate logging to work with log4j2, I’ve tried to configure separate log files for netatmo and rules by adding the following lines:
### Custom Loggers ###
# Logger - netatmo.log
log4j2.logger.netatmo.name = openhab.binding.netatmo
log4j2.logger.netatmo.level = DEBUG
log4j2.logger.netatmo.additivity = false
log4j2.logger.netatmo.appenderRefs = netatmo
log4j2.logger.netatmo.appenderRef.netatmo.ref = NETATMO
log4j2.logger.rules.name = smarthome.model.script.RULES
log4j2.logger.rules.level = DEBUG
log4j2.logger.rules.additivity = false
log4j2.logger.rules.appenderRefs = rules
log4j2.logger.rules.appenderRef.rules.ref = RULES
# Audit file appender
log4j2.appender.netatmo.type = RollingRandomAccessFile
log4j2.appender.netatmo.name = NETATMO
log4j2.appender.netatmo.fileName = /var/log/openhab2/netatmo.log
log4j2.appender.netatmo.filePattern = /var/log/openhab2/netatmo.log.%i
log4j2.appender.netatmo.append = true
log4j2.appender.netatmo.layout.type = PatternLayout
log4j2.appender.netatmo.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.netatmo.policies.type = Policies
log4j2.appender.netatmo.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.netatmo.policies.size.size = 10MB
log4j2.appender.netatmo.strategy.type = DefaultRolloverStrategy
log4j2.appender.netatmo.strategy.max = 10
log4j2.appender.rules.type = RollingRandomAccessFile
log4j2.appender.rules.name = RULES
log4j2.appender.rules.fileName = /var/log/openhab2/rules.log
log4j2.appender.rules.filePattern = /var/log/openhab2/rules.log.%i
log4j2.appender.rules.append = true
log4j2.appender.rules.layout.type = PatternLayout
log4j2.appender.rules.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.rules.policies.type = Policies
log4j2.appender.rules.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.rules.policies.size.size = 10MB
log4j2.appender.rules.strategy.type = DefaultRolloverStrategy
log4j2.appender.rules.strategy.max = 10
The logfiles are created but remains empty:
-rw-r--r-- 1 openhab openhab 0 Oct 21 23:07 netatmo.log
-rw-r--r-- 1 openhab openhab 0 Oct 21 23:07 rules.log
-rw-r--r-- 1 openhab openhab 214 Oct 22 00:37 audit.log
-rw-r--r-- 1 openhab openhab 330214 Oct 22 01:00 openhab.log
-rw-r--r-- 1 openhab openhab 359114 Oct 22 01:01 events.log
Any clues?
BR,
/Janne
