I want to reactivate my Openhab installation (latest version on Raspberry/Stretch/Java build 1.8.0_65-b17).
The binding produces the following DEBUG output:
```csv
2020-04-13 10:38:11.310 [DEBUG] [g.internal.handler.WebserviceHandler] - Refresh job scheduled to run every 60 min. for 'tankerkoenig:webservice:WebserviceName'
2020-04-13 10:38:11.535 [DEBUG] [enig.internal.handler.StationHandler] - Initializing Tankerkoenig handler 'tankerkoenig:station:WebserviceName:Station1'
and
java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@7edd22::DecryptedEndPoint@1ca45ad{creativecommons.tankerkoenig.de/188.68.35.147:443<->/192.168.178.30:35808,CLOSED,fill=-,flush=C,to=1/0}
at org.openhab.binding.tankerkoenig.internal.data.TankerkoenigService.getResponseString(TankerkoenigService.java:70) ~[?:?]
at org.openhab.binding.tankerkoenig.internal.data.TankerkoenigService.getTankerkoenigDetailResult(TankerkoenigService.java:93) ~[?:?]
at org.openhab.binding.tankerkoenig.internal.data.TankerkoenigService.getStationDetailData(TankerkoenigService.java:51) ~[?:?]
at org.openhab.binding.tankerkoenig.internal.handler.StationHandler.updateDetailData(StationHandler.java:155) ~[?:?]
at org.openhab.binding.tankerkoenig.internal.handler.StationHandler.lambda$0(StationHandler.java:96) ~[?:?]
The tankerkoenig delivers no prices for gas. What may be wrong with my configuation. Ich double checked the syntax and the API-KEY. Thanks
Can’t really say how your Java build 1.8.0_65-b17 relates to mine, but is sounds suspicious.
Do you get anymore logentries before the error starting with [DEBUG] ?
What is this IP “188.68.35.147”? It seems the error is related to that.
Edit:
Please confirm the used channel syntax in the items file. You can use PaperUI to get the correct one, select Configuration - Things - Station1. Behind each channel you find an icon to copy the correct syntax.
I would say the correct one is: "tankerkoenig:station:WebserviceName:Station1:e10"
Regarding the Java version, the openhab documentation states:
For best compatibility, namely with the openHAB Cloud service [myopenhab.org](https://www.myopenhab.org/) and the [Eclipse IoT Marketplace](https://www.openhab.org/docs/configuration/eclipseiotmarket.html), the minimum recommended Java 8 revision is "161". Attention: Most package managers serve an **older revision** . Check your current Java version by opening a command line console and typing java -version :
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode)
