I also have a L530 that stopped working after a power outage.
Found out auto-firmware update is on it has latest 1.4.1 now.
I do not recall 100% but I believe it’s operated through the cloud because there is no means to enable access control in the app for that device but no matter if I try ‘direct access’ or ‘KLAP secured’, Thing always says invalid http-response (9001)
I just set up an H200 hub. Didn’t realize that it wasn’t supported like the H100. I was able to get temp & RH Things from Tapo T310 multisensor working using the Matter Binding on openHABian 5.1.4, but don’t see the battery switch that is supposed to be there. Does anyone have experience with this?
I recognized a few interesting behaviors of my Tapo Pxxx while testing my new S112 device integration.
I always had the “403” Http error on two of my 10 Pxxx plugs with the new Firmware 1.4.6 from time to time (the device shortly goes to offline state after the error, and comes back automatically). I remembered that these are my two Plugs, that have programmed some actions in the Tapo App (not in openhab). I got the same error on all of my Pxxx when I started my Tapo App. After switching off my actions, and stopping my Tapo app, I get rid of all my errors.
For me it looks like, that the devices can only connect to one client (either the Tapo internal API or the Openhab Binding API). It is not a real big thing, because Openhab reconnects and logins automatically again, but it is at least good to know.
It would be good if all the people in this thread, who mentions this error, could double check if you can confirm this behavior.
I found out, that it is only possible to get data from max 10 slave devices at the H100. The H100 can handle more, but the API of H100 that is used for the binding only delivers data for 10. As well good to know.
Hey, guys.
I’m having an issue with my Tapo devices. I had 14 devices:
1 Hub (H100)
1 light strip (L900)
1 power strip (P300)
2 smart plugs (P115)
4 humidity sensors (T310)
5 contact sensors (T110)
I also have a Kasa Plug HS110 that I had originally configured on the Kasa app and connected to OH via the TP-Link Smart Home binding. One or two months ago, I removed it from the Kasa app and added it to the Tapo app, but it’s still connected to OH via the TP-Link binding.
I had had no issues so far, until…
I purchased 3 contact sensors (T110) more, added them to the Tapo app, and they were automatically added to the OH Inbox. Once I added the things, 2 of the “old” contact sensors went offline on OH.
The binding reports the following
10:50:16.158[DEBUG] [org.openhab.binding.tapocontrol.internal.devices.wifi.hub.TapoHubHandler] - child not found in deviceList '802E1589185C19C800B7C8500F6F84XXXXXXXXXXX'
10:50:16.160[DEBUG] [org.openhab.binding.tapocontrol.internal.devices.wifi.hub.TapoHubHandler] - child not found in deviceList '802EF32782E137A4E305700260690YYYYYYYYYY'
10:50:16.414[DEBUG] [org.openhab.binding.tapocontrol.internal.discovery.TapoDiscoveryService] - Discovery-Service unsupported device discovered 'Tapo HS11 (Washing Machine)
Configuration
OH Version: 5.2.3
The Tapo App has Third-Party Compatibility enabled.
On, OH, the Cloud Login thing has:
Cloud Discovery enabled.
UDP Discovery disabled.
Discover Only Online Devices disabled.
The HUB Thing has:
Secured KLAP HTTP Protocol enabled.
Background Discovery enabled.
All devices have their latest firmware.
What Else Have I Tried?
I disabled the two offline sensors and re-enabled, but they remainded OFFLINE. I unplugged the HUB, waited for a while, and plugged it back in. Then 2 of the new sensors remained OFFLINE after all other things had gone back to ONLINE, including the 2 old sensors that were previously OFFLINE.
I plugged in the light strip and the thing went ONLINE.
As I wrote in my previous post the Tapo Binding only can recognize up to 9 slave devices connected to one hub. I bought one more hub, and moved the new slave devices to the other hub. Then I have added the second hub and the sensors to the things and it worked for me.
Thanks for the info, @mannmanny. I hadn’t seen that part of your post.
It seems the number of slave devices is just a bit higher for me, as I had 13-15 (I can’t remember er if the power strip is also connected to the hub) working devices, including the Kasa plug I recently added.
I understand the issue is on Tapo’s side. Is there a way to report that as a bug?
[Update]: You’re right, right now I have 12 devices connected to the hub.
I tried for other reasons to report errors to Tapo, but I was not successfull. I newer got an answer from Tapo in the forum. There is no place I found for developers and the API.
Have you by any chance tried connecting to the hub via Matter?
Or do you know if the same happens when connected to the official Alexa, IFTTT, or google Home integrations? I only have HomeKit, and, apparently, that one is not natively supported either.
