But the issue is not that the configuration is rejected because of an invalid format, but no bridge is configured. Did you configure a bridge for that thing?
But it does not say “Bridge offline”, it says “no bridge configured”. Looking at the code this means that the bridge is not set. The bridge is offline because of “API rate limit exceeded”. This has nothing to do with config validation in core.
You have to configure the bridge on the plug thing and check why your API rate limit is exceeded.
Okay the API-Rate exceeded is new. but is nothing to do with the configuration issue.
Got ist at the moment still on the old versions. Mabybe it could be that the bridge tries to connect too much time because of the configuration error.
Fair point and sorry for the confusion, for testing purposes I tried to use the thing without a bridge (had the hope that it could directly connect to the IP without cloud). So with the bridge configured I’m back to the API rate limit:
09:22:21.947 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:5dd2373e6f' changed from UNINITIALIZED (DISABLED) to INITIALIZING
09:22:22.234 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:5dd2373e6f' changed from INITIALIZING to UNKNOWN
09:22:22.243 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:779a193b58' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
09:22:22.249 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:779a193b58' changed from INITIALIZING to UNKNOWN
09:22:23.404 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:5dd2373e6f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): API rate limit exceeded (-20004)
09:22:23.408 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:779a193b58' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
09:22:26.255 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:779a193b58' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE (COMMUNICATION_ERROR): Device Offline
Just to add, I’m also seeing the API rate limit exceeded (-20004) when setting up the bridge, even with the configuration issues fixed using the snapshot jar. Any guidance on how we can narrow down what’s going wrong? The Tapo app is working fine with the same account details and inside the same network, so I don’t think it’s blocking at an account or IP level.
So I’ve decided to go back to 3.3.0 and the API rate limit exceeded (-20004) exists. I’m sure that 2 months ago it did not exist on 3.3.0, so I believe that something has changed in the Tapo Cloud and @Bigdesaster needs to investigate it further, otherwise pairing new devices with OH may be at risk.
I don’t know if error reading device-configuration: 'For input string: "30.0"' has any consequence, but in my opinion it is not causing the API rate limit exceeded (-20004) problem. I had error reading device-configuration: 'For input string: "30.0"' during several weeks (including weeks where I was using 3.4.0.M2) and only recently (maybe 3 days ago) I’ve started having the API rate limit exceeded (-20004) problem.
Now I’m back to 3.4.0.M2 but if further tests are necessary with 3.3.0 pls let me know.
Again: the core issue is fixed. If you use latest snapshots, it‘ll not occur. Since it was present in 3.3 release any new install of 3.3 will of course show the same problem.
Please show the yaml (code-view) of the bridge thing. I’ll check that. If there is a username/password, just exchange it with username/password. For checking initialization it doesn’t matter if the login succeeds.
Login is actually not working cause of the other issue. But the things will work even if bridge (cloud) is offline.
Issue is not only in bridge. Same issue with thing configuration:
I can’t reproduce that. I have downloaded latest snapshot (which is #3106, I’m not sure which build date #3103 has, the PR was merged 9 days ago and usually a build is done every night), installed the TapoControl binding and created a bridge. The JSON db looks like that:
I’ve only been using OpenHAB for a few days and I’m impacted by the “API rate limit” issue. After some debugging, it seems like the plugin is hard-coded to use the terminal UUID 0A950402-7224-46EB-A450-7362CDB902A2, which results in {"error_code":-20004,"msg":"API rate limit exceeded"} being returned by the API no matter what username/password you specify. I imagine this is because everyone’s TapoBridge plugin is using the same value.
If I change the UUID to something else, it succeeds:
@J-N-K
Every night could not be, cause i downloaded 3103 two or three days ago.
Then it could be that the core fix was merged after 3103 snapshot. let us review in a few days.
@Poggs
Thank you for hour hint. .
I think that should be the reason. If yo are on the way to fix it you can do. Otherwise i can fix it tomorrow or the day after.
