The error is fixed, Color temperature is working fine now.
I did have to use the parameter “sendFrequency” in the Colorpicker of the sitemap, otherwise it would still drop the signals quite often. But with sendFrequency=1000, it is working like a charm now.
I can not test L610 as I do not own it, and since On-Time seems to be not supported, that signal should be removed from the Thing L630.
Other than that I am confident that (just from device test results point of view) the changes can be implemented to the binding.
Thank you so much for the quick on-demand support!
hello @Bigdesaster, i’m looking for a contact sensor, and i’ve seen the Tapo one.
to make it work, i need the tapo hub H100.
i would like to buy the HUB (needed) and the contact sensor, but actually are not supported by binding.
do you think could be possible to add the support for this device on your binding?
as last time for L530, i can send you the log you need
let me know, and if you would like to manage another challange on this product i will be pleasured to be a cavy
I afraid that communication protocoll for sensors and hub is not like the direct wifi devices. So it may be not so easy as the normal one.
To investigate that communication i need a hub and some sensors.
But the windows-sensors are too expensive. There are much cheaper Zigbee sensors available.
I understand technocal issues…
Hub + 1 sensor are about 50€ in total on amazon. I dunno if i can post link here,but if you look for hub you can see the bundle with sensor.
About 25€ for each piece.
That’s why male smart home with tapp could be a nice idea and at the same time cheap
try to manage color first time from tapo app, and then try to use openhab…i’ve seen that first time needs to be changed from app and then openhab works…
Ah okay got it. Works for me now fine. The bulbs were setted in tapo control app to predefined mode with daylight. That blocks color control via tapocontrol binding.
Ok that is a usefull information to fix this. Thank you.
Not testet yet but it should be reproducible if you set it agay to “daylight” with app und try to change with oh3 again.
