Here is the trace log
2022-01-10 15:28:57.215 [TRACE] [pocontrol.internal.device.TapoDevice] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) starScheduler: create job with interval : 30
2022-01-10 15:28:58.471 [TRACE] [pocontrol.internal.device.TapoDevice] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA) schedulerAction
2022-01-10 15:28:58.473 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA) DeviceConnetor_queryInfo from 'http://192.168.129.153/app?token=2D9718974197D397FF973E972097C097'
2022-01-10 15:28:58.474 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA) sendAsncRequest to 'http://192.168.129.153/app?token=2D9718974197D397FF973E972097C097' with cookie 'TP_SESSIONID=C0A5CFA63796B89744878387F5879E87'
2022-01-10 15:28:58.505 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA) requestCompleted '{"error_code":0,"result":{"device_id":"8022310D8180F003B5BF4ED6745514C11DE2622C","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-FF-D4-BA","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"UsOhZGlvIGUgVFY=","location":"","avatar":"plug","longitude":-86465,"latitude":406386,"has_set_location_info":true,"ip":"192.168.129.153","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":3,"rssi":-39,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}'
2022-01-10 15:28:58.507 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA) received result: {"error_code":0,"result":{"device_id":"8022310D8180F003B5BF4ED6745514C11DE2622C","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-FF-D4-BA","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"UsOhZGlvIGUgVFY=","location":"","avatar":"plug","longitude":-86465,"latitude":406386,"has_set_location_info":true,"ip":"192.168.129.153","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":3,"rssi":-39,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}
2022-01-10 15:28:59.218 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) sending login to url 'http://192.168.129.160/app'
2022-01-10 15:28:59.219 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) create handhsake with payload: {"method":"handshake","params":{"key":"-----BEGIN PUBLIC KEY-----\nMIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQCvCP8+a4ZxM9d5xjPncQHn88YMJ8M+8srbWcaw\r\nxu194rDRjIxzp5F5pwg4U2BpjFlXlbU4E5vddkwKQ+F2xjFh9nYUKvJxQA0La3V0dw9rHk7hLdsh\r\nUCsHuBFSiBaeqvztcvtYKevJCSTlvt/6Ktdi3epRZd2eoehapIosRKl/OwIDAQAB\n-----END PUBLIC KEY-----\n"},"requestTimeMils":1641828539218}
2022-01-10 15:28:59.220 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) sendRequest to 'http://192.168.129.160/app' with cookie ''
2022-01-10 15:28:59.751 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) received awnser: {"error_code":0,"result":{"key":"jc6vj4EeSWXnDrsfflOJhbP/6Ts4OtsOL/Bk1ZL3TbG/UaBFyy6549F7mrdOIbhPIrBnXqymMlGcoRufb6hTebyjAkdCzn2g6xzSK7nQ7IgJAZTIiCAfXB1NS+DzvKzSp7oRUt037oBjU2l2igodnLSES+OFMUNXXpB+4n6ZjG4="}}
2022-01-10 15:28:59.752 [TRACE] [ocontrol.internal.helpers.TapoCipher] - Init TapoCipher with key: jc6vj4EeSWXnDrsfflOJhbP/6Ts4OtsOL/Bk1ZL3TbG/UaBFyy6549F7mrdOIbhPIrBnXqymMlGcoRufb6hTebyjAkdCzn2g6xzSK7nQ7IgJAZTIiCAfXB1NS+DzvKzSp7oRUt037oBjU2l2igodnLSES+OFMUNXXpB+4n6ZjG4=
2022-01-10 15:28:59.755 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) got cookie: 'TP_SESSIONID=B786992EBDB99A63C504769CEC7CE57F'
2022-01-10 15:28:59.756 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) sendRequest to 'http://192.168.129.160/app' with cookie 'TP_SESSIONID=B786992EBDB99A63C504769CEC7CE57F'
2022-01-10 15:28:59.935 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) received result: {"error_code":0,"result":{"token":"41A316622E2C2ABE069F9EC9F3F0B95B"}}
2022-01-10 15:28:59.936 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) DeviceConnetor_queryInfo from 'http://192.168.129.160/app?token=41A316622E2C2ABE069F9EC9F3F0B95B'
2022-01-10 15:28:59.936 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) sendAsncRequest to 'http://192.168.129.160/app?token=41A316622E2C2ABE069F9EC9F3F0B95B' with cookie 'TP_SESSIONID=B786992EBDB99A63C504769CEC7CE57F'
2022-01-10 15:28:59.952 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) requestCompleted '{"result":{"device_id":"80227F7E16FE84060344E9D43D5DECEE1F37479C","fw_ver":"1.0.7 Build 210629 Rel.174901","hw_ver":"1.0","type":"SMART.TAPOPLUG","model":"P110","mac":"6C-5A-B0-EF-42-1B","hw_id":"2FB30EF5BF920C44099401D396C6B55B","fw_id":"00000000000000000000000000000000","oem_id":"18BDC6C734AF8407B3EF871EACFCECF5","overheated":false,"ip":"192.168.129.160","time_diff":0,"ssid":"QXZlaXJvLURvbW90aWM=","rssi":-76,"signal_level":1,"latitude":406389,"longitude":-86489,"lang":"pt_PT","avatar":"plug","region":"Europe/Lisbon","specs":"","nickname":"RGVzdW1pZGlmaWNhZG9y","has_set_location_info":true,"device_on":true,"on_time":1228,"default_states":{"type":"last_states","state":null}},"error_code":0}'
2022-01-10 15:28:59.953 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P110:2a2ef37a29:8d49c446e9) received result: {"result":{"device_id":"80227F7E16FE84060344E9D43D5DECEE1F37479C","fw_ver":"1.0.7 Build 210629 Rel.174901","hw_ver":"1.0","type":"SMART.TAPOPLUG","model":"P110","mac":"6C-5A-B0-EF-42-1B","hw_id":"2FB30EF5BF920C44099401D396C6B55B","fw_id":"00000000000000000000000000000000","oem_id":"18BDC6C734AF8407B3EF871EACFCECF5","overheated":false,"ip":"192.168.129.160","time_diff":0,"ssid":"QXZlaXJvLURvbW90aWM=","rssi":-76,"signal_level":1,"latitude":406389,"longitude":-86489,"lang":"pt_PT","avatar":"plug","region":"Europe/Lisbon","specs":"","nickname":"RGVzdW1pZGlmaWNhZG9y","has_set_location_info":true,"device_on":true,"on_time":1228,"default_states":{"type":"last_states","state":null}},"error_code":0}
2022-01-10 15:29:06.759 [TRACE] [pocontrol.internal.device.TapoDevice] - (tapocontrol:P100:6731f67b2d:C0C9E37658C6) schedulerAction
2022-01-10 15:29:06.759 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E37658C6) DeviceConnetor_queryInfo from 'http://192.168.129.150/app?token=242F962EB33EE23EF03ED03ED13EC13E'
2022-01-10 15:29:06.760 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E37658C6) sendAsncRequest to 'http://192.168.129.150/app?token=242F962EB33EE23EF03ED03ED13EC13E' with cookie 'TP_SESSIONID=D00FD10FC90F490F450F8D0F0B0F6F0F'
2022-01-10 15:29:06.800 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E37658C6) requestCompleted '{"error_code":0,"result":{"device_id":"802200E417335EB9A90D90BD5F477AF91DD57765","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-76-58-C6","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"QXF1ZWNlZG9y","location":"","avatar":"plug","longitude":-86489,"latitude":406388,"has_set_location_info":true,"ip":"192.168.129.150","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":1,"rssi":-74,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}'
2022-01-10 15:29:06.801 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E37658C6) received result: {"error_code":0,"result":{"device_id":"802200E417335EB9A90D90BD5F477AF91DD57765","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-76-58-C6","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"QXF1ZWNlZG9y","location":"","avatar":"plug","longitude":-86489,"latitude":406388,"has_set_location_info":true,"ip":"192.168.129.150","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":1,"rssi":-74,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}
2022-01-10 15:29:15.662 [TRACE] [pocontrol.internal.device.TapoDevice] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1) schedulerAction
2022-01-10 15:29:15.663 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1) DeviceConnetor_queryInfo from 'http://192.168.129.152/app?token=7258FA597E493A4978495249F349E649'
2022-01-10 15:29:15.664 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1) sendAsncRequest to 'http://192.168.129.152/app?token=7258FA597E493A4978495249F349E649' with cookie 'TP_SESSIONID=A25AFC591E69396848785B786B786A78'
2022-01-10 15:29:15.711 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1) requestCompleted '{"error_code":0,"result":{"device_id":"802224E5D956A55685AE5BF9FAA9A6471DE3408E","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-FF-D1-A1","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"QXF1ZWNlZG9yIMOzbGVvIA==","location":"","avatar":"plug","longitude":-86489,"latitude":406388,"has_set_location_info":true,"ip":"192.168.129.152","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":2,"rssi":-53,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}'
2022-01-10 15:29:15.712 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1) received result: {"error_code":0,"result":{"device_id":"802224E5D956A55685AE5BF9FAA9A6471DE3408E","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-FF-D1-A1","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"QXF1ZWNlZG9yIMOzbGVvIA==","location":"","avatar":"plug","longitude":-86489,"latitude":406388,"has_set_location_info":true,"ip":"192.168.129.152","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":2,"rssi":-53,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}
2022-01-10 15:29:22.371 [TRACE] [pocontrol.internal.device.TapoDevice] - (tapocontrol:P100:6731f67b2d:C0C9E3963230) schedulerAction
2022-01-10 15:29:22.371 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3963230) DeviceConnetor_queryInfo from 'http://192.168.129.151/app?token=7432E2338623C523FF235E2343239323'
2022-01-10 15:29:22.372 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3963230) sendAsncRequest to 'http://192.168.129.151/app?token=7432E2338623C523FF235E2343239323' with cookie 'TP_SESSIONID=C647C740DF305F335B0313029112BD12'
2022-01-10 15:29:22.417 [TRACE] [ntrol.internal.api.TapoDeviceHttpApi] - (tapocontrol:P100:6731f67b2d:C0C9E3963230) requestCompleted '{"error_code":0,"result":{"device_id":"802276D916E481D2AAC519233901C9351DDB14C1","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-96-32-30","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"Q2FuZGVlaXJvIGR1cGxv","location":"","avatar":"plug","longitude":-86491,"latitude":406387,"has_set_location_info":true,"ip":"192.168.129.151","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":3,"rssi":-45,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}'
2022-01-10 15:29:22.417 [TRACE] [rol.internal.api.TapoDeviceConnector] - (tapocontrol:P100:6731f67b2d:C0C9E3963230) received result: {"error_code":0,"result":{"device_id":"802276D916E481D2AAC519233901C9351DDB14C1","fw_ver":"1.4.9 Build 20210621 Rel. 30941","hw_ver":"1.20.0","type":"SMART.TAPOPLUG","model":"P100","mac":"C0-C9-E3-96-32-30","hw_id":"9994A0A7D5B29645B8150C392284029D","fw_id":"1D18AD293A25ABDE41405B20C6F98816","oem_id":"D7C5ADFD37188938BA82FD0FE208D1E7","specs":"EU","device_on":false,"on_time":0,"overheated":false,"nickname":"Q2FuZGVlaXJvIGR1cGxv","location":"","avatar":"plug","longitude":-86491,"latitude":406387,"has_set_location_info":true,"ip":"192.168.129.151","ssid":"QXZlaXJvLURvbW90aWM=","signal_level":3,"rssi":-45,"region":"Europe/Lisbon","time_diff":0,"lang":"pt_PT","default_states":{"type":"last_states","state":null}}}
192.168.129.160
is the P110 device.
