i had flashed MagicHome LED Controller with Tasmota. So far so good. Everything is fine. I don’t know how to configure the channel for color changing and dimming. The Power (On Off) is working fine.
I have newest openhab, tasmota 11.1 on the device and a mqtt server. Cause of the switch working I think it is a mqtt command/state or something problem.
I got tutorials but there’s openhab2 another LED controller or no mqtt or or or. But not the constellation I have.
Can someone give me one example thing/channel/item configuration.
The item is just a color item, nothing special about it.
Note: commandTopic and stateTopic may look different in your situation, Tastmota by default used cmnd/NameOfTasmotaDevice/HSBCOLOR
till now i made everything in UI. Since Openhab3 I had no need to do configuration in files. I begun with Openhab 2 the scripting was horrible for me.
But if there is no other way…
If you have ideas please.
this looks very nice.
I try to do configuration work within UI so some things are different I hope I can “translate” to UI.
I will give feedback.
First of all I habe to tell that I haven’t an item to change color. Slider Color Picker or Wheel they did not show anything there is only a frame but nothing to slide or click.
Second as you can see Topics for the switch are litte bit different. Is ther a change in tasmota? Is this order a special for LED Stripe???
