You star…
I was getting frustrated yesterday, lack of understanding, lack of ability and even lack of sleep.
I was also having some issues with the MQTT service no starting, filldged; shouldn’t have!.. So I took it out and reinstalled form Openhab config
Then I took out the MQTT broker binding and started again… That seems to have helped and the auto update properties are now working, well doing something I need to further understand anyway.
Progress me thinks…!
I am pretty sure that the stat/…/LWT will fix the issue complrtly once I understand the effect of the various settings. That inst working yet but I think it just needs a transform file.
I did try none standard strings in the section that identifies the payload but it didn’t seem to work, I may have another go.
Also I discovered that ‘Select a Profile for the link’ has a huge effect on what the switch respond to.
two switches linked to a single device seem to synchronize, or not, in one or other direction, but not necessary both, based on a combination of profile and auto update properties.
Is on pushing state info to the to the profile and the other responding to it? … Reading to do I guess.
I did make an item file, minimal info, and discovered that it defined the item but that paper UI will not edit it… Good to know that is anticipated behavior.
I think on balance files are probably the way to go for things items and associated organizational bits.
The UI is nice but I suspect lacks some functionality right now.
Perhaps more impotently though, I lack functionality and will learn faster building code, even if that is a bigger jump.
Are there any pitfalls with respect to version?
IE. if I find a code example from an older version are those objects/methods, probably not the right terminology, going to work. Additionally are there any new ones that would be preferred to an older, outdated approach.
Obviously I need to read the docs but my initial searches turned up a load of stuff saying don’t do that, use the UI, and more detailed searching is hard without context.
I am 100% behind the do it one way and only one way strategy, I agree anything else would likely be horrible to maintain somewhere down the line.
I am going to strip out all ‘things’ device specific and have another go using your example.
I don’t see a problem leaving the broker defined with the UI as it is acting like a service essentially.
If you think that is not a good call I would like to understand why, so I can make the right call.
All the help is much appreciated folks.
Sad to say I expect I will need much more one way or another.
I have separate questions about rules and other similar topics, but I am going to leave those for another thread, which can wait until the basics are in place.
I will be asking ‘better’ questions from a more informed perspective by then I suspect.
Al
