TCP binding not open connection OH2
Hi
I want to read a tcp connection (Openhab in client connect to a Device 192.168.1.22:23)
I have install tcp1
creat a TCP.cfg
# all parameters can be applied to both the TCP and UDP binding unless
# specified otherwise
# Port to listen for incoming connections
# port=50290
# Cron-like string to reconnect remote ends, e.g for unstable connection or remote ends
reconnectcron=* * * * * ?
# Interval between reconnection attempts when recovering from a communication error,
# in seconds
retryinterval=5
# Queue data whilst recovering from a connection problem (TCP only)
#queue=true
# Maximum buffer size whilst reading incoming data
#buffersize=1024
# Share connections within the Item binding configurations
#itemsharedconnections=true
# Share connections between Item binding configurations
#bindingsharedconnections=true
# Share connections between inbound and outbound connections
#directionssharedconnections=false
# Allow masks in ip:port addressing, e.g. 192.168.0.1:* etc
#addressmask=true
# Pre-amble that will be put in front of data being sent
#preamble=
# Post-amble that will be appended to data being sent
#postamble=\r\n
# Perform all write/read (send/receive) operations in a blocking mode, e.g. the binding
# will wait for a reply from the remote end after data has been sent
#blocking=false
# timeout, in milliseconds, to wait for a reply when initiating a blocking write/read
#  operation
#timeout=3000
# Update the status of Items using the response received from the remote end (if the
# remote end sends replies to commands)
# updatewithresponse=true
# Timeout - or 'refresh interval', in milliseconds, of the worker thread
refreshinterval=250
# Timeout, in milliseconds, to wait when "Selecting" IO channels ready for communication
selecttimeout=1000
# Used character set
#charset=ASCII
a linky.item
String linky “linky” { tcp="<[192.168.1.22:23:‘REGEX((.*))’]" }
and a Linky.rules
rule “Linky”
Item linky changed
logDebug(“Linky”, “data:”+linky.state.toString)
But nothing in log item and rule load without error but no data log
and openhab not open the TCPconnection (check with “ss -t -a -n | grep .1.22”)
If i try with telnet 192.168.1.22 23 that work fin and i found connection in “ss -t -a -n | grep .1.22”
Can you help me?
