This actually means that it should be officially added to the distro now, right? Is this something you would already feel able to do? It is at least partially documented how it is done
i can try to add it…ill find the link that tells how. and yes, it should be added to the distro, would solve all these issues.
stupid me! you provided tge link!
how do i know what its depencies are? do i make the changes on the github master site? wsnt to make sure o do this right.
reading up on all of this, really dont feel comfortable or confident doing this quite yet!
is there anyone else?
I will make a PR that adds the TCP/UDP binding to OH2, if that’s OK.
that would be great! thanks for the lead in the correct direction with this…
i have one problem with the binding, and cant say whether it existed under oh1…
after the system is up for about 36 hrs, i lose connection to the device via tcp, and have to restart oh to get it going again…maybe i can use a touch every 24 hrs or so via a rule, but havent tackled that yet.
The link seems to be broken. Is it fixable?
If you just want to install the binding you don’t need the link anymore because it is part of the distribution now:
Edit: if you don’t see it activate those two options:
