open topic, getting no help, please help with last post.
I don’t think there is any configuration needed for tcp/udp binding at all apart from the item configuration, at least OH1 has no parameters in openhab.cfg
for tcp/udp binding.
ok, i will try that, although, all i did was define the listening port.
also, the tcp binding wiki says that at least one parameter has to be defined to even start the binding.
From Wiki:
In order to bind an item to a remote host:port, you need to provide configuration settings. The easiest way to do so is to add some binding information in your item file
Please note the last sentence:
Ok, so I will delete the incoming port in tcp.cfg, and delete that file to see if it helps. I have already provided config settings in the items file.
Made no difference: Here’s the most of the log
`18:11:14.343 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.tcp(1)] The deactivate method has thrown an exception
java.lang.NullPointerException
at org.openhab.binding.tcp.AbstractSocketChannelBinding.deactivate(AbstractSocketChannelBinding.java:718)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)
at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:913)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:902)[32:org.apache.felix.scr:2.0.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:260)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_65]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryUngetService(ServiceFactoryUse.java:258)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.ungetService(ServiceFactoryUse.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.ungetService(ServiceConsumer.java:50)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.ungetService(ServiceRegistrationImpl.java:581)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.ungetService(ServiceRegistry.java:540)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:661)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.delegateAddService(ResourceTracker.java:48)[14:com.eclipsesource.jaxrs.publisher:5.3.0.201512270850]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:40)[14:com.eclipsesource.jaxrs.publisher:5.3.0.201512270850]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:753)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:700)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[32:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
18:11:14.467 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.tcp(1)] The deactivate method has thrown an exception
at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:61)[2:org.apache.felix.metatype:1.1.2]
at o
According to the wiki your item definition (grabbed from your other post) is wrong:
Wiki: tcp=">
your item: tcp:=">
i will try it. thank you
sihui,
that helped a lot, thank you…still issues though…i couldnt get the binding to load because i removed the cfg file because someone else said to. then, i redid it, only atating the refreah interval, and it worked for one of my otems, but not the other…i then reatarted oh2, now the binding isn’t starting at all, at least i dont think so…
every time i request a state change, it says there is no channel associated with that item.
should i just define all parameters in tcp.cfg? is it called tcp.cfg, or something else like tcp/udp.cfg?
I don’t use the tcp binding ,so I can only repeat what is in the wiki and what the other guys told you:
you don’t need a tcp.cfg as long as you have the config in the item definition (for example the ip adress).
Don’t put anything twice in these two files, for example an ip adress in the tcp.cfg AND in your items definition.
So my assumption with your problem: the item definition is wrong, maybe another typo …
Edit:
I recommend to enable debugging for that specific binding, maybe the log tells you more:
https://github.com/openhab/openhab-distro/blob/master/docs/sources/getting-started.md#using-the-shell
karel
i assume, though could be wrong, this is you.
https://groups.google.com/forum/m/#!topic/openhab/obUEWEKe_lg
Im having the same issue as this post. Though, under oh2. binding works if i make a change to any part of the configs.
Here is my debug log:
openhab> log:display org.openhab.binding.tcp
19:13:44.471 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The interval to retry connection setups will be set to the default value of 5
19:13:44.474 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels within an Item will be set to the default value of true
19:13:44.476 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between the items with the same direction will be set to the default value of true
19:13:44.478 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between directions will be set to the default value of true
19:13:44.482 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Listening for incoming connections on /0:0:0:0:0:0:0:0:25001
19:13:44.491 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default vaulue of ""
19:13:44.493 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The postamble for all write operations will be set to the default vaulue of ""
19:13:44.496 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - Updating states with returned values will be set to the default vaulue of true
19:13:44.498 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The characterset will be set to the default vaulue of ASCII
19:13:44.584 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.udp(3)] The deactivate method has thrown an exception
at org.openhab.binding.tcp.AbstractDatagramChannelBinding.deactivate(AbstractDatagramChannelBinding.java:733)
19:13:44.724 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.udp(3)] The deactivate method has thrown an exception
And my debug log:
openhab> log:tail
19:41:38.545 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent [unknown:512] - org.openhab.binding.tcp
19:41:38.831 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.TCPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.tcpgenericbindingprovider, component.id=0, service.id=100, service.bundleid=174, service.scope=bundle} - org.openhab.binding.tcp
19:41:38.961 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.tcp.protocol.UDPBindingProvider}={component.name=org.openhab.binding.tcp.protocol.udpgenericbindingprovider, component.id=2, service.id=101, service.bundleid=174, service.scope=bundle} - org.openhab.binding.tcp
19:41:40.239 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTING - org.openhab.binding.tcp
19:41:40.246 [DEBUG] [ab.binding.tcp.internal.TCPActivator] - TCP/UDP binding has been started.
19:41:40.248 [DEBUG] [org.openhab.binding.tcp ] - BundleEvent STARTED - org.openhab.binding.tcp
19:42:00.603 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
19:42:13.722 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'ntp:ntp:local' has been added.
19:42:13.746 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'zwave:device:1543f5c1ca3:node10' has been added.
19:42:13.776 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'zwave:serial_zstick:1543f5c1ca3' has been added.
19:42:13.974 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'LR_Lamp-zwave:device:1543f5c1ca3:node10:switch_dimmer' has been added.
19:42:13.977 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'zwave_device_1543f5c1ca3_node10_scene_number-zwave:device:1543f5c1ca3:node10:scene_number' has been added.
19:42:13.983 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'zwave_device_1543f5c1ca3_node10_switch_dimmer-zwave:device:1543f5c1ca3:node10:switch_dimmer' has been added.
19:42:14.022 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link 'ntp_ntp_local-ntp:ntp:local' has been added.
19:42:14.029 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link 'zwave_device_1543f5c1ca3_node10-zwave:device:1543f5c1ca3:node10' has been added.
19:42:14.202 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'ntp_ntp_local' has been added.
19:42:14.208 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'zwave_device_1543f5c1ca3_node10' has been added.
19:42:14.221 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'zwave_device_1543f5c1ca3_node10_scene_number' has been added.
19:42:14.245 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'zwave_device_1543f5c1ca3_node10_switch_dimmer' has been added.
19:42:36.984 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-tcp': No matching features for openhab-binding-tcp/0.0.0
19:42:46.853 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
19:42:48.944 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
19:42:52.735 [INFO ] [ulation.internal.HueEmulationServlet] - Started Hue Emulation service at /api
19:42:53.527 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:1543f5c1ca3:node10' changed from UNINITIALIZED to INITIALIZING
19:42:53.563 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:1543f5c1ca3:node10' changed from INITIALIZING to OFFLINE
19:42:53.644 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'zwave:serial_zstick:1543f5c1ca3': java.lang.NoSuchMethodError: org.eclipse.smarthome.config.core.Configuration.get(Ljava/lang/String;)Ljava/lang/Object;
java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.config.core.Configuration.get(Ljava/lang/String;)Ljava/lang/Object;
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:179)[96:org.eclipse.smarthome.core:0.8.0.201604202038]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:72)[96:org.eclipse.smarthome.core:0.8.0.201604202038]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:56)[96:org.eclipse.smarthome.core:0.8.0.201604202038]
at org.eclipse.smarthome.core.thing.internal.ThingManager$7.run(ThingManager.java:659)[102:org.eclipse.smarthome.core.thing:0.8.0.201604202038]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.config.core.Configuration.get(Ljava/lang/String;)Ljava/lang/Object;
at org.openhab.binding.zwave.handler.ZWaveSerialHandler.initialize(ZWaveSerialHandler.java:69)
at org.eclipse.smarthome.core.thing.internal.ThingManager$7$1.call(ThingManager.java:662)
at org.eclipse.smarthome.core.thing.internal.ThingManager$7$1.call(ThingManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:170)
... 3 more
19:42:53.661 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:1543f5c1ca3' changed from UNINITIALIZED to INITIALIZING
19:42:53.644 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:1543f5c1ca3' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org.eclipse.smarthome.config.core.Configuration.get(Ljava/lang/String;)Ljava/lang/Object;
19:42:54.407 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The interval to retry connection setups will be set to the default value of 5
19:42:54.409 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels within an Item will be set to the default value of true
19:42:54.411 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between the items with the same direction will be set to the default value of true
19:42:54.413 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to share channels between directions will be set to the default value of true
19:42:54.416 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Listening for incoming connections on /0:0:0:0:0:0:0:0:25001
19:42:54.418 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.tcp, component.name=org.openhab.binding.tcp.protocol.tcp, component.id=1, service.id=289, service.bundleid=174, service.scope=bundle} - org.openhab.binding.tcp
19:42:54.422 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default vaulue of ""
19:42:54.424 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The postamble for all write operations will be set to the default vaulue of ""
19:42:54.426 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - Updating states with returned values will be set to the default vaulue of true
19:42:54.428 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The characterset will be set to the default vaulue of ASCII
19:42:54.433 [INFO ] [b.core.service.AbstractActiveService] - TCP Refresh Service has been started
19:42:54.481 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread TCP Refresh Service
java.nio.channels.ClosedSelectorException
at sun.nio.ch.SelectorImpl.selectedKeys(SelectorImpl.java:74)[:1.8.0_65]
at org.openhab.binding.tcp.AbstractSocketChannelBinding.execute(AbstractSocketChannelBinding.java:1347)[174:org.openhab.binding.tcp:1.8.2]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:157)[168:org.openhab.core.compat1x:2.0.0.201605091907]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173)[168:org.openhab.core.compat1x:2.0.0.201605091907]
19:42:54.497 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread TCP Refresh Service
at sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:83)[:1.8.0_65]
at sun.nio.ch.SelectorImpl.selectNow(SelectorImpl.java:105)[:1.8.0_65]
at org.openhab.binding.tcp.AbstractSocketChannelBinding.execute(AbstractSocketChannelBinding.java:1340)[174:org.openhab.binding.tcp:1.8.2]
19:42:54.508 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread TCP Refresh Service
19:42:54.518 [INFO ] [b.core.service.AbstractActiveService] - TCP Refresh Service has been shut down
19:42:54.538 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.tcp(1)] The deactivate method has thrown an exception
19:42:54.843 [DEBUG] [org.openhab.binding.tcp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.udp, component.name=org.openhab.binding.tcp.protocol.udp, component.id=3, service.id=290, service.bundleid=174, service.scope=bundle} - org.openhab.binding.tcp
19:42:54.855 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.udp(3)] The deactivate method has thrown an exception
at org.apache.felix.cm.impl.helper.BaseTracker.ungetRealService(BaseTracker.java:207)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:161)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1444)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1400)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8]
19:42:55.025 [ERROR] [org.openhab.binding.tcp ] - [org.openhab.binding.tcp.protocol.udp(3)] The deactivate method has thrown an exception
Looks like a lot of trouble
What java version are you using, Oracle Java or OpenJDK?
It is recommended to use Oracle …
i just figured it out! have to define
host=xxx.xxx.xxx.xxx:port
in tcp.cfg in services folder.
works like a charm now!
i renig that statement. did a reboot…not working…seems to get working of i edit the tcp.cfg file once openhab has started. maybe something doesnt load in the correct order? how might i fix that issue?
I’m not very experienced with oh2, no idea.
In oh1 it is possible to set the time interval for loading the openhab.cfg file and the various other config files, I don’t know if that is possible in oh2 too.
oh1:
# The refresh interval for the main configuration file. A value of '-1'
# deactivates the scan (optional, defaults to '-1' hence scanning is deactivated)
#mainconfig:refresh=
Good luck.
making changes to tcp.cfg after openhab has started makes the binding work. any way to simulate this as a script?
If you are using Linux, a touch tcp.cfg
should do it.
