Hi all,
I’m using the daily snapshot of openhab2 and I have installed the TCP binding 1.9 via paper UI.
I have a mobotix S15 (with IP 192.168.0.20) on my maindoor. I have setup that the mobotix sends a tcp command via port 5100 to the openhab server everytime the door bell is activated.
In the tcp dump I noticed that the command is send on the correct port. Then I have configured the TCP binding as follows:
# all parameters can be applied to both the TCP and UDP binding unless
# specified otherwise
# Port to listen for incoming connections
port=5100
# Cron-like string to reconnect remote ends, e.g for unstable connection or remote ends
#reconnectcron=0 0 0 * * ?
# Interval between reconnection attempts when recovering from a communication error,
# in seconds
#retryinterval=5
# Queue data whilst recovering from a connection problem (TCP only)
#queue=true
# Maximum buffer size whilst reading incoming data
#buffersize=1024
# Share connections within the Item binding configurations
itemsharedconnections=true
# Share connections between Item binding configurations
bindingsharedconnections=true
# Share connections between inbound and outbound connections
directionssharedconnections=false
# Allow masks in ip:port addressing, e.g. 192.168.0.1:* etc
addressmask=true
# Pre-amble that will be put in front of data being sent
#preamble=
# Post-amble that will be appended to data being sent
#postamble=\r\n
# Perform all write/read (send/receive) operations in a blocking mode, e.g. the binding
# will wait for a reply from the remote end after data has been sent
blocking=false
# timeout, in milliseconds, to wait for a reply when initiating a blocking write/read
# operation
#timeout=3000
# Update the status of Items using the response received from the remote end (if the
# remote end sends replies to commands)
updatewithresponse=false
# Timeout - or 'refresh interval', in milliseconds, of the worker thread
refreshinterval=250
# Timeout, in milliseconds, to wait when "Selecting" IO channels ready for communication
#selecttimeout=1000
# Used character set
charset=ASCII
in my item file I have defined the following item
Switch Klingel {tcp="<[ON:192.168.0.20:5100:'REGEX((ON))']", autoupdate="false" }
In the openhab log I see the following after restart of openhab
2017-01-29 18:31:45.475 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The maximum buffer will be set to the default value of 1024
2017-01-29 18:31:45.475 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The interval to retry connection setups will be set to the default value of 5
2017-01-29 18:31:45.475 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The cron job to reset connections will be set to the default value of 0 0 0 * * ?
2017-01-29 18:31:45.475 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The setting to queue write operation until a channel gets connected will be set to the default value of true
2017-01-29 18:31:45.475 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Listening for incoming connections on /0:0:0:0:0:0:0:0:5100
2017-01-29 18:31:45.480 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The maximum time out for blocking write operations will be set to the default value of 3000
2017-01-29 18:31:45.480 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default value of ""
2017-01-29 18:31:45.480 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The postamble for all write operations will be set to the default value of ""
2017-01-29 18:31:45.480 [INFO ] [ing.tcp.protocol.internal.TCPBinding] - The characterset will be set to the default value of ASCII
Based on that information I would expect that all connections will be accepted coming from any IPv4 addresses on port 5100.
However, I have tried to setup and I noticed the following in the log.
2017-01-29 18:17:20.959 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Received connection request from /192.168.0.20:5100
2017-01-29 18:17:20.959 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Disconnecting the unallowed remote end /192.168.0.20:5100
Somehow it’s not allowing a connection from the mobotix.
Anybody any idea how to solve that issue?
Thanks in advance.
Best Regards,
Marcel
