Hello together,
I want to use the UDP binding to send a string from OpenHAB (UDP client) to another network device which runs an UDP server.
It works perfectly fine for a switch item:
Switch Light_Test "Test" (Lights) { udp=">[ON:192.168.1.7:25001:'MAP(udp.map)'], >[OFF:192.168.1.7:25001:'MAP(udp.map)']" }
I also want to send some other information to the UDP server like the current outdoor temerature which I am getting via KNX.
But how do I achieve this? What is the syntax to do this, i.e. what is the “command” and how do I reference the string/number in the “transformationrule”?
Tried the following, but it failed as I expected
Number Weather_Temperature "Aussentemperatur [%.1f °C]" <temperature> (Weather_Chart, Temperature) { knx="<9.001:0/7/0", udp=">[192.168.1.7:25001] }
Thanks & Regards,
Christian
