Hi there,
I’m new to all of this so sorry if this is posted in the wrong place or something obvious.
I’ve been enjoying playing with openHABian on a Pi2 and configuring it mostly with Paper UI but done a bit of ssh and just figured out how to see the logs in Karaf console.
I’m trying to get the TCP/UDP binding working but I can’t get it to show up in the inbox or bindings config. I can check the install switch in the add ons - bindings list and it pops up a message saying its installed but it doesn’t turn up anywhere else. I’ve tried the search button in the inbox and it finds any other bindings installed but not this one.
I’ve just finished a fresh image with updates done and only the TCP/UDP binding installed with the same result.
I have no experience with openHAB 1 and only basic skills in linux so may be missing something obvious. I’ve had a look at the karaf logs on different levels but either see nothing about the driver except its installed, or a huge continuous list if I change the log level to trace or debug. I don’t know what I’m looking for though so any pointers would be great.
Am I doing something stupid or is there an issue with this binding in openHABian?
