ebusd has a tcp interface which I would like to connect to read and write values.
ebusd accepts connection on 8888 and would return a value on “read”
read [-f] [-m SECONDS] [-s QQ] [-d ZZ] [-c CIRCUIT] [-p PRIO] [-v|-V] [-n] [-i VALUE[;VALUE]*] NAME [FIELD[.N]]
-f force reading from the bus (same as '-m 0')
-m SECONDS only return cached value if age is less than SECONDS [300]
-c CIRCUIT limit to messages of CIRCUIT
-s QQ override source address QQ
-d ZZ override destination address ZZ
-p PRIO set the message poll priority (1-9)
-v increase verbosity (include names/units/comments)
-V be very verbose (include names, units, and comments)
-n use numeric value of value=name pairs
-i VALUE read additional message parameters from VALUE
NAME NAME of the message to send
FIELD only retrieve the field named FIELD
N only retrieve the N'th field named FIELD (0-based)
And values can be set by a “write”
write [-s QQ] [-d ZZ] -c CIRCUIT NAME [VALUE[;VALUE]*]
-c CIRCUIT CIRCUIT of the message to send
VALUE a single field VALUE
Some items would have reading only character, other should be updatable.
Could somebody give me a hint how to setup the tcp.cfg and item for the following example:
Read Only Item
Number Item zuluftmenge ............
read>:
read -f -V zuluftmenge
receive<:
wolfcwl zuluftmenge data=50 m³/h
Read/Write Item
Number Item aktstufe ...
read>:
read -f -V aktstufe
receive<:
wolfcwl aktstufe data=0
write>:
write -c wolfcwl w_aktstufe 0
receive(ignore)<:
BYPASS AUS;FROST AUS
