After a frustrating experience with another Zigbee USB dongle I bought the Telegesis ETRX357USB-LRS but I can’t get it working on my RPi3 with Openhabian and openHAB 2.5.0~M2-1
The dongle is discovered in PaperUI and I’m able to add it but it just won’t come online. Here is the debug log
2019-08-19 22:31:34.912 [DEBUG] [e.telegesis.handler.TelegesisHandler] - Initializing ZigBee Telegesis serial bridge handler.
2019-08-19 22:31:34.912 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_telegesis:04000A5E].
2019-08-19 22:31:34.913 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2019-08-19 22:31:34.914 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 39166
2019-08-19 22:31:34.914 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 75E34CE9E3FA69DA
2019-08-19 22:31:34.915 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 30241D4FCACE09B2C5E796D89724C6F7
2019-08-19 22:31:34.916 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2019-08-19 22:31:34.917 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=true
2019-08-19 22:31:34.917 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 30241D4FCACE09B2C5E796D89724C6F7
2019-08-19 22:31:34.919 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 30241D4FCACE09B2C5E796D89724C6F7
2019-08-19 22:31:34.920 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2019-08-19 22:31:34.921 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising network
2019-08-19 22:31:34.926 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2019-08-19 22:31:34.928 [DEBUG] [e.telegesis.handler.TelegesisHandler] - ZigBee Telegesis Coordinator opening Port:'/dev/ttyUSB0' PAN:98fe, EPAN:75E34CE9E3FA69DA, Channel:11
2019-08-19 22:31:34.932 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2019-08-19 22:31:35.933 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2019-08-19 22:31:35.934 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2019-08-19 22:31:35.936 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=50, maxRetries=2]
2019-08-19 22:31:35.937 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
2019-08-19 22:31:35.938 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
2019-08-19 22:31:35.939 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2019-08-19 22:31:35.940 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 1280
2019-08-19 22:31:35.941 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher starting
2019-08-19 22:31:35.942 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster 1280
2019-08-19 22:31:35.942 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 25
2019-08-19 22:31:35.943 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster 25
2019-08-19 22:31:35.944 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager initialize: networkState=UNINITIALISED
2019-08-19 22:31:35.944 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
2019-08-19 22:31:35.945 [DEBUG] [.zigbee.internal.NotificationService] - NotificationService is shutdown. Not scheduling com.zsmartsystems.zigbee.ZigBeeNetworkManager$3
2019-08-19 22:31:35.946 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis dongle initialize.
2019-08-19 22:31:35.947 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 19200 baud, flow control FLOWCONTROL_OUT_NONE.
2019-08-19 22:31:35.950 [ERROR] [ding.zigbee.handler.ZigBeeSerialPort] - Serial Error: Port /dev/ttyUSB0 does not exist.
2019-08-19 22:31:35.951 [ERROR] [ngle.telegesis.ZigBeeDongleTelegesis] - Unable to open Telegesis serial port
2019-08-19 22:31:35.952 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to OFFLINE
2019-08-19 22:31:35.952 [DEBUG] [.zigbee.internal.NotificationService] - NotificationService is shutdown. Not scheduling com.zsmartsystems.zigbee.ZigBeeNetworkManager$3
It says that the port does not exist, any ideas?
