I have issues With Telegram action ( sendTelegram() ). I am running Build #567.
If i make a test rule like this:
rule "Test ON"
Item Test1 changed to ON
sendTelegram("bot1", "Modus ist jetzt abwesend.")
everything is fine. But if i use the same function in this rule:
rule "Anwesenheit 3"
Item Abwesend changed to OFF
logInfo("Abwesenheit", "Abwesend is inaktiv")
var DateTime beulerAus = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T" + "22:00")
var DateTime beulerAn = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T" + "07:00")
var DateTime tvAus = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T" + "23:59")
var DateTime tvAn = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T" + "07:00")
if(beulerAus.afterNow && beulerAn.beforeNow){
sendCommand(Kueche_Steckdose_outlet,ON)
if(tvAus.afterNow && tvAn.beforeNow){
sendCommand(TV_Steckdose_outlet,ON)
sendCommand(Esszimmer_Netatmo_mode,"program")
sendTelegram("bot1", "Modus ist jetzt anwesend.")
It doesn’t work and logs this:
[ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Anwesenheit 3': An error occured during the script execution: The name 'sendTelegram(<XStringLiteralImpl>,<XStringLiteralImpl>)' cannot be resolved to an item or type.
any ideas?
Jens
