Is there a way that I’m not seeing to send messages via a telegram bot when you’re defining a rule in the web UI? Or does it have to be in a rules file under /etc/openhab/rules/ ?
Same question for putting statements in the log file.
Just trying to implement a message to a telegram bot when defining a rule in the web interface. I don’t see any way to define an action to do that. If it has to be a rules file I’m okay with that.
Currently I go to Rules → Create Rule → Add Action and there doesn’t seem to be any way there to setup which bot and what content to send.
I do see Send Log message under Show All which I missed before.
Rossko’s question relates to the fact that there is no graphical configuration of actions in the rule creation editor. It is quite possible to have actions run but you have to choose the Run Script action and then add the code for the action as found in the docs. For example, if you use a js script your telegram line would be:
