I have a Linky counter and it is plugged to my raspberry and I can get extract data using my own code and other scripts. However, the binding here seems not work. It doesn’t create a meter once connected.
In OpenHAB log files I see
2022-01-11 18:11:30.678 [WARN ] [nternal.serial.TeleinfoReceiveThread] - Got invalid frame. Detail: "The label '_PTARIF' is unknown"
What could I do to debug more?
To make it works from the console I do
stty -F /dev/ttyUSB2 1200 sane evenp parenb cs7 -crtscts
and when running my code which checks the checksum I get:
MOTDETAT 000000
ADCO 811961330504
OPTARIF HC..
ISOUSC 60
HCHC 006154244
HCHP 009027961
PTEC HP..
IINST 005
IMAX 090
PAPP 01210
Could it be serial-port configuration problem? What could I do to debug it more?
