Hello all,
I’m totally new to both Linux and OpenHab, but I jumped right in to it anyway, unfortunately I’m stuck with a problem when I’m trying to activate the binding to Tellstick 2.2.0 I get a massive error log (the pasted part is not all), I’m not sure if I’m supposed to install anything else to the Raspberry or only the raspian and then activate the binding?
Have anyone of you old timers seen this type of issue before?
Appreciate any help
Sorry for double posting, but I didn’t get the tags right the first time.
/Jocke
2017-12-27 22:30:50.249 [ERROR] [l.discovery.TellstickBridgeDiscovery] - Could not load telldus core, please make sure Telldus is installed and correct 32/64 bit java.
java.lang.UnsatisfiedLinkError: Unable to load library ‘telldus-core’: Native library (linux-arm/libtelldus-core.so) not found in resource path (/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.1.3.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar)
