So are you saying that with the v2 version you don’t get any new items in
the inbox in PaperUI ?
You are aware that the item configuration is really different for OpenHab2
bindings ?
I normally uninstall the v1 version, but it should work anyway.
I have not used the Inbox, instead I used to have a look in events.log.
This is one of the working frames i have seen there
2016-03-09 03:24:18.064 [ItemStateChangedEvent ] - Weather_Ground_Temp changed from 7.3 to 7.4
Are there any differences due to look for the info. in Inbox regarding to events.log, I ask just to learn, I am kind of a newbe to openhab/openhab2 ?
So the reason for the non-existing info. is probebly the Item-configuration, I use the very same as for openHAB Tellstick Binding 1.9.0.xx, could you please advice me some info, about the changes. Thank’s in advange!!
If the telldus 2.0 binding has a dependency on this package, this is actually the problem since this package is not available on openHAB 2 (instead, the Jetty HTTP client should be used, see this discussion). I just noticed that the ESH documentation is actually buggy in this respect…
The package becomes available as soon as you install the 1.x compatibility feature, though.
got the error again
11:58:30.714 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/opt/openhab2/addons/org.openhab.binding.tellstick-2.0.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.tellstick [150]
Unresolved requirement: Import-Package: org.apache.http
Tried to start it
150 | Installed | 80 | 2.0.0.201602212121 | Tellstick Binding
openhab> start 150
Error executing command: Error executing command on bundles:
Error starting bundle150: Could not resolve module: org.openhab.binding.tellstick [150]
Still no go
But if i do a clean install and start with demo package in addons.cfg.
It works to put the Tellstick binding 2.0 in the addons folder.
Then it starts an discovers things from my telldus-net.
Great, thanks!
And this is the very same info.as I can see in the ESH console-window during runtime started in ESH, right?
I will do some more tests, with the 2.0…binding, let you know further on
A big step forward is done, Thank’s again!!
So far have I found this info. in the log, when using binding 2.0…
16:37:05.927 [DEBUG] [andler.core.TelldusCoreBridgeHandler] - Sensor Event for TellstickSensor [sensorId=167, protocol=fineoffset, model=temperaturehumidity, timeStamp=Wed Mar 09 16:36:17 CET 2016, data={HUMIDITY=65, TEMPERATURE=7.3}] event TellstickSensorEvent [sensorId=167, model=temperaturehumidity, protocol=fineoffset, data=65, timestamp=1457537825000]
16:40:30.254 [DEBUG] [andler.core.TelldusCoreBridgeHandler] - Sensor Event for TellstickSensor [sensorId=11, protocol=mandolyn, model=temperaturehumidity, timeStamp=Wed Mar 09 16:39:30 CET 2016, data={HUMIDITY=30, TEMPERATURE=3.2}] event TellstickSensorEvent [sensorId=11, model=temperaturehumidity, protocol=mandolyn, data=3.1, timestamp=1457538030000]
And this must be what I expect the Tellstick DUO to deliver from in this case, 2 different sensors.
So my question now I assume is, where can I find information about the item configuration for OH2 and this binding?
Yes, I can see the actual devices there, and also in HABMIN.
I have done some struggling with the configuration, but I can even now see them in BasicUI & ClassicUI, so I am pleased.
I can see in HABMIN that the devices(Items in HABMIN), after an SCAN where called names like tellstick_sensor_… in the beginning. I tried to change name of them in the configuration-files but then they will not work( no info. was delivered to Basic/Classic UI. Booth UI,s seems to work but no updating.
Have I done something wrong with the configuration or is this as it should be, no problem for me, just querious?
Another question regarding to “Yes, but if you have a basic or duo you need a 32 bit java.” I am running Linux Mint 17.2 32 bit, is it the very same with java in Linux ‘something’ 64 bit.
It is really only the lack of maintainers, sorry for that - I am doing all openHAB 2 PRs completely alone
I am thinking of different solutions to this problem, but none of them are ready yet to ease things.
Hi!
Just found out that my temperature/humidity probe doesn’t send any new
values regarding humidity.
It has worked just great until maybe a week ago. I will let it roll and
also OH2, just to find out if there will be some change during time. I
have twice seen something similar but one time I did an restart of OH2
and that helps, and the other time was it like it started to function
without anything.
Attend some info. from log.tail
Just let me now if you need some other / more info., just very learning
to help.
Hi, Have tried to get this running on a fresh OpenHAB2 Beta3 install but having trouble doing so.
Here is the error I get:
2016-07-30 14:51:47.534 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.tellstick-2.0.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.tellstick [191]
Unresolved requirement: Import-Package: org.openhab.core.library.types
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1245)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1217)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1207)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:504)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:358)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:310)[8:org.apache.felix.fileinstall:3.5.0]
2016-07-30 14:51:47.536 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.tellstick-2.0.0-SNAPSHOT.jar
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:509)[8:org.apache.felix.fileinstall:3.5.0]
OpenHAB installed on Ubuntu Server, using Oracle JDK 8 and JAR shared above. Any help would be appreciated!
