I’m trying to control some light through a control box that allows me to connect via telnet.
On connection the box put’s out some status information (which should be ignored). To switch on light a command with “e1:1” must be sent with telnet. I tried to implement it with the tcp& udp binding. In my items file i set up the switch:
Switch “Kueche1” (gKt) { tcp=">[ON:192.168.1.11:23:‘e1:1’], >[ON:192.168.1.11:23:'e1:0]" }
The configuration gets loaded, and when I start OH it also connects to the box and in the log in ready out the initial status information of the box and then I get an error that this informtion can not be parsed.
I cannot control the lights, but i think this related to the error on connection.
Can someone help on this?
Thanks and best regards
haui
