Good morning I’m trying to assign a numeric temperature value to uu items by collecting the data on a web page but I can’t assign it
ITEMS
Number TempTermostato < temperature >
RULES
rule “Stato Temperatura”
Time cron “0/10 * * * * ?”
var int Temp = sendHttpGetRequest(“http://192.168.1.80/tempT.php?idx=44”)
logInfo( “myRule” , "TemperaturaT is " + Temp)
TempTermostato.state = Temp
logInfo( “myRule” , "TemperaturaT is " + TempTermostato.state)
ERROR
2020-04-03 12:35:40.448 [INFO ] [clipse.smarthome.model.script.myRule] - TemperaturaT is 19
Error during the execution of rule ‘Stato Temperatura’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.core.library.items.NumberItem.setState(org.eclipse.smarthome.core.types.State) on instance: TempTermostato (Type=NumberItem, State=NULL, Label=null, Category=temperature)
Don’t forget your Temp is a string variable, your Item is a Number type. TempTermostato.postUpdate(Temp)
will do its best to parse that string into a number.
I strongly advise adding a timeout to your http action.
Thanks another error, rules change with TempTermostato.postUpdate(Temp)
ERROR
2020-04-03 12:49:20.395 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Stato Temperatura’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(org.eclipse.smarthome.core.items.Item,java.lang.Number) on instance: null
2020-04-03 13:00:20.336 [INFO ] [clipse.smarthome.model.script.myRule] - TemperaturaT is 19
2020-04-03 13:00:20.343 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘Stato Temperatura’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.Number) on instance: null
Don’t forget to address that timeout issue before you move on.
If you do not, your http request may wait forever and you rule will “hang up”.
When enough instances of your rule have hung up waiting, no other rules will be able to start.
