I’m a bit stuck why my temperature is not updating in OH2, works fine in the _Default sitemap !
The zwave device is “Z-Wave Node 6: ZW074 4 in One MultiSensor (G5)”.
In my items file I’ve added the following (obtained the zwave from paper UI) :
Number Temp_Outside “Temperature: [%.1f C]” {channel=zwave:device:155c4282ffd:node6:sensor_temperature}
In my sitemap, I have the following
Text item=Temp_Outside icon=“temperature”
When viewing the item in Habmin I can see values against the _default sitemap.
