Dear all,
I am tried to visualize a temperature from the KNX bus in my openhab installation, but I cannot make it work. The temperature is available on the bus (tested via group monitoring in ETS).
Below, you’ll see some snippets of the current configuration.
knx.things
Bridge knx:ip:bridge [
type=“TUNNEL”,
ipAddress=“192.168.1.63”,
localIp=“192.168.1.200”] {
Thing device 2F_Switch_Actuator [
address=“1.1.201”,
fetch=true,
pingInterval=300
Type switch : 2F_Technical_Light “2F_Technical_Light” [ ga=“2/0/110+<2/1/110” ]
Type switch : 2F_Bathroom_Light “2F_Bathroom_Light” [ ga=“2/0/120+<2/1/120” ]
Type switch : 2F_Bedroom_Light “2F_Bedroom_Light” [ ga=“2/0/130+<2/1/130” ]
Type switch : 2F_Storage_Light “2F_Storage_Light” [ ga=“2/0/140+<2/1/140” ]
Thing device 2F_Bedroom_Switch [
address=“1.1.220”,
fetch=true,
pingInterval=300,
readInterval=3600
Type number : 2F_Bedroom_Temperature “2F_Bedroom_Temperature” [ ga=“9.001:<2/2/130” ]
home.items
Number 2F_Bedroom_Temperature “Temperatuur [%.1f °C]” (2F_Bedroom_Temperature) [“Temperature”] {channel=“knx:device:bridge:2F_Bedroom_Switch:2F_Bedroom_Temerpature”}
tmp.sitemap
sitemap tmp label=“Test” {
Frame {
Switch item=1F_Bedroom_Back_Light icon=“light” label=“Room1”
Switch item=1F_Bedroom_Front_Light icon=“light” label=“Room2”
Switch item=2F_Storage_Light label=“Room3”
Switch item=2F_Technical_Light label=“Room4”
Switch item=2F_Bedroom_Light label=“Room5”
Switch item=2F_Corridor_Light label=“Room6”
Text item=2F_Bedroom_Temperature label=“Room Temperature”
The light control and status is working properly; but I cannot get the temperature working. The item is shown in the basic-UI, but the value is not populated.
When looking into the openhab-logs, I do not find any item related to the temperature reading. I have already struggled for a day with this issue. I hope someone can help me out.
