Hi guys,
i made an upgrade from knx 1 to knx 2.4.
Almost everything is working fine, but i am struggling with my temperature thing.
the configuration of all knx things are equal, but the temperature thing is not working.
Without any channels the thing goes online.
But if i set any channel the thing runs into the error “UNINITIALIZED - HANDLER_CONFIGURATION_PENDING”.
After some channel link and unlink Sessions, the thing goes online and get the Right temp values.
But after a restart or initialization of all things, the temp thing shows the error again.
Here is my thing config:
Thing device Temperatur "Temperatur"
Type number : Temperatur "Raumtemperatur" [ga="9.001:<3/0/0"]
Here the item
Number Temperatur "Raumtemperatur [%.1f °C]" <temperature> (CH_Wohnraum, Temperatur) { channel="knx:device:bridge:Temperatur:Temperatur"}
Hope you have an advice
best regards
vaillan
