Hi All,
I have openhab1 running on a raspberry pi,
In the .items file there is the following …
Group esp3
Number esp_workshop_temp “Workshop Temperature[%.0f Degree’s Celsius]” <temp_icon> (esp3) {mqtt="<[mymosquitto:/Workshop_1/DHT_Workshop/Temperature:state:default]"}
Group enode
Number enode_1 “DS18B20 Temperature [%.2f Degree’s Celsius]” <temp_icon> (enode) {mqtt="<[mymosquitto:/enode1/PZEM/from/temperature:state:default]"}
When looking at MQTT traffic using mqtt SPY …
/Workshop_1/DHT_Workshop/Temperature 23.00 and
/enode1/PZEM/from/temperature {“T0”:25.19}
The DHT_Workshop/Temperature is displayed correctly on the openhab web interface but no value is displayed for the PZEM device.
I notice the data value is inside curly brackets,while the working workshop nodes data is only the actual temperature value - “T0” being the device ID of the sensor connected to the node,up to 10 DS18B20’s can be connected to the same node and 25.19 is the temperature value.
What must the line be changed to in the items file to display the sensor number and its temperature value,are going to add more sensors to this node ?
tia
Dave
