This may be a noob question, but I am migrating an old binding to v2. The old code reads Temperature values in the form of Bigdecimals. I would like to call my ThingHandler.updateState(ChannelID, Temperature) but it seems that method won’t accept BigDecimal arguments. I think I need to cast the values to another number type, but how?
The method expects a subclass of type State
. Depending on what you channel definition is in the xml of the thing definition it’s very likely either:
new DecimalType(temperature)
(If channel is <item-type>Number</item-type>
) or
new QuantityType(temperature, SIUnits.CELSIUS)
(assuming it’s Celsius) if <item-type>Number:Temperature</item-type>
Many thanks Hillbrand. I implemented the update code as follows…
import javax.measure.quantity.Temperature;
import org.eclipse.smarthome.core.library.types.OnOffType;
import org.eclipse.smarthome.core.library.types.QuantityType;
import org.eclipse.smarthome.core.library.unit.SIUnits;
protected void setChannelValues(NeoHubInfoResponse.DeviceInfo device) {
updateState(CHANNEL_SET_TEMP, new QuantityType<Temperature>(device.getCurrentSetTemperature(), SIUnits.CELSIUS));
updateState(CHANNEL_ROOM_TEMP, new QuantityType<Temperature>(device.getCurrentTemperature(), SIUnits.CELSIUS));
updateState(CHANNEL_FLOOR_TEMP, new QuantityType<Temperature>(device.getCurrentFloorTemperature(), SIUnits.CELSIUS));
updateState(CHANNEL_AWAY_MODE, OnOffType.from(device.isAway()));
updateState(CHANNEL_STANDBY_MODE, OnOffType.from(device.isStandby()));
updateState(CHANNEL_HEATING_MODE, OnOffType.from(device.isHeating() || device.isPreHeat()));
