Hello everyone
I’m using Opebnhab to switch all my 433 Mhz plugs and beginn with heating control via Homematic. The binding works so far but i got an Problem with the sitemap (Basic UI). The Temperature from the sensors wont show in basic UI but in the Paper Ui it works.
the item looks like this
Number ActTemp "Aktuelle Temperatur" <temperature> (gTempAll) {channel="homematic:HmIP-STH:ccu:XXXXXXXXXXXX:1#ACTUAL_TEMPERATURE"}
in sitemap
Default item=ActTemp
I’m running openhab 2.1.0 on a Raspberry pi 3 the java version is 1.8.0_151
If u need additional information let me know
