Oh, that’s great!
Thanks Thomas.
It’s not available in PaperUI as a channel though.
Is this true for forecast as well - like:
{channel=“weatherunderground:weather:local:forecastToday#icon”}
I will give it a try.
Oh, that’s great!
Thanks Thomas.
Yes, it is available:
Open the Local Weather binding in PaperUI and click on the Show More link on the upper right half of the page.
Damn it!
You’re right.
Now I remember that I have used “Show more” many months ago, but somehow forgot about it.
Thanks a lot for the reminder.
Have a great Christmas Season.
I have read all posts here, but die not find a solution for my use case:
Wunderground 2.0 (included in OH 2.2)
German localization.
As you mentioned the image files do not match, which is my problem.
I would like to use these icons:
https://peter.build/weather-underground-icons/
Options:
ConditionID (not provided by Wunderground!?)
Renaming manually - this is the actual issue.
Currently the weather forcast today here is chancerain which is Regen möglich.
I tried:
regen-m%C3%B6glich.svg
regen+m%C3%B6glich.svg
regen möglich.svg
bedeckt.svg (cloudy) works.
So the main issue are the Umlaute (special characters in German)
My widget code:
<img src="{{ServerPath}}/{{IconSet}}/{{itemValue('Weather_Forecast_0').split(' ').join('-') | lowercase }}.svg"/>
Another Option I could think of (but don’t know how to realize it) would be a transform in the widget code (translate the german condition back into englisch in the background).
<img src="{{ServerPath}}/{{IconSet}}/{{MAP(weather.map):%sitemValue('Weather_Forecast_0').split(' ').join('-') | lowercase }}.svg"/>
Why is the current condition translated (Regen) into German, but not the weekdays?
Even with this adjustment, I still get Monday, Tuesday etc.
<div ng-init="ServerPath='http://192.168.178.50:8080/static/weather_icons'; IconSet='white'; daysnames={'Sunday': 'So', 'Monday': 'Mo', 'Tuesday': 'Di', 'Wednesday': 'Mi', 'Thursday': 'Do', 'Friday': 'Fr', 'Saturday': 'Sa'}">
Could you please post your config for weatherunderground? (Things and Items) I’m thinking there’s something mixed.
for German Translation you have to:
the WU-API returns the JSON like this:
"forecast":{
"txt_forecast": {
"date":"13:39 CET",
"forecastday": [
"period":0,
"icon":"clear",
"icon_url":"http://icons.wxug.com/i/c/k/clear.gif",
"title":"Sonntag",
"fcttext":"Meistens klar. Höchsttemperatur 36F. Wind aus S und wechselhaft.",
"fcttext_metric":"Meistens klar. Höchsttemperatur 4C. Wind aus S und wechselhaft.",
"pop":"0"
as I see it, the “icon”-Attribute is of course english (as should the filenames), and the texts are translated. I don’t use the WU-binding at the moment, but I can imagine, you using some kind of Transformation for you icon-item? and perhaps the language given in the API isn’t “DL”.?
Good Morning Thomas and Merry Christmas!
With WU Profile you mean the Thing settings in Paper UI? I have set it to “German” from the dropdown menu.
I am currently using the WU binding in OH 2.2, which does not require an additional config.
(previously I used the weather binding with weather.cfg - back than I had set DL - but with OH2 the file is obsolete - right?
My thing in PaperUI:
My items look for instance like this (no transform):
// Current Weather
String Weather_Current "Wetter [%s]" <weather> (G_jdbc) {channel="weatherunderground:weather:local:current#conditions"}
Image Weather_Curr_Icon "Wetter Icon" (G_jdbc) {channel="weatherunderground:weather:local:current#icon"}
DateTime Weather_ObsTime "Zeitpunkt [%s]" (G_jdbc) {channel="weatherunderground:weather:local:current#observationTime"}
Number Weather_Temperature "Temperatur [%.1f °C]" <temperature> (G_Numbers) {channel="weatherunderground:weather:local:current#temperature"}
Number Weather_Temp_Feel "Gef. Temperatur [%.1f °C]" <temperature> (G_Numbers) {channel="weatherunderground:weather:local:current#feelingTemperature"}
Number Weather_Prec_Amnt_1h "Regenmenge 1h [%.0f mm]" <rain> (G_Numbers) {channel="weatherunderground:weather:local:current#precipitationHour"}
Number Weather_Prec_Amnt_24h "Regenmenge 24h [%.0f mm]" <rain> (G_Numbers) {channel="weatherunderground:weather:local:current#precipitationDay"}
Number Weather_Humidity "Luftfeuchte [%d %%]" <humidity> (G_Numbers) {channel="weatherunderground:weather:local:current#relativeHumidity"}
Number Weather_Pressure "Luftdruck [%.0f mb]" <pressure> (G_Numbers) {channel="weatherunderground:weather:local:current#pressure"}
Number Weather_Wind_Speed "Wind [%.1f km/h]" <line> (G_Numbers) {channel="weatherunderground:weather:local:current#windSpeed" }
String Weather_Wind_Dir "Wind Dir [%s]" <line> (G_jdbc) {channel="weatherunderground:weather:local:current#windDirection" }
Can I check the WU-API response with my current settings somewhere?
I guess the “icon” channel in the WU 2.0 binding is the url - so how to get the bare name of the icon (“icon”:“clear”) in your response above.
This would enable me to use this in the template to link to the proper local file.
Thanks for your help
Hi there,
at first, I’m sorry, I tend to forget about configuring OH2 with PaperUI (I solely use files… #oldfashioned).
So let’s do this:
Weather Underground delivers an API with a pretty good JSON response. The WeatherUnderground binding takes the JSON, makes some channels and throws is back in for using.
I don’t use the binding (I’ll tell you, what I do later on), so I don’t know exactly, whether all JSON-Attributes are taken 1:1 as channels (but my bet is it should do).
current#icon
has the whole URL to the icon, you can either strip the sole icon name. i would have expected current:icon
and current:icon_url
as channels.So, you asked on how you can see the JSON-response. that’s pretty straightforward. As you already know your API-key, just klick on this (of Course using your credentials ):
$current_observation.icon
and $current_observation.icon_url
"response": {
"version":"0.1",
"termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
"features": {
"conditions": 1
"forecast": 1
, "current_observation": {
"precip_today_in":"0.00",
"precip_today_metric":"0",
"icon":"cloudy",
"icon_url":"http://icons.wxug.com/i/c/k/cloudy.gif",
As you can also see, there are a lot more attributes here like “precip_today_in” and “precip_today_metric” - so, the binding makes it easier for you to use those in your units.
And that’s basically, what I do: taking the JSON and parsing it for my wanted items.
My experience is, with the configuration in the WU-Profile to metric and german plus the “DL” argument in the API-URL you get metric units in texts ("fcttext_metric":"Teilweise bedeckt. Tiefsttemperatur 3C. Wind aus SSW mit 15 bis 25 km/h."
). The Binding can only use the “DL” argument, so it could be, that there’s only imperial units in german texts. AFAIR that was what I got before changing the values in the profile.
next thing you need to know using weather-underground: take a closer look to the JSON, you will see, that you get a bunch of information with $current_observation
, that’s the current#...
channels in the binding. Then you get two periods for today in the forecast, which represent day
and night
for today, thats forecastToday:...
channels. I don’t know, where the night-attributes go… but then you get the rest like forecastTomorrow forecastDay2 … forecastDay9
- again, I don’t know where the night-attributes of the next days go (they’re present in the JSON):
"period":2,
"icon":"partlycloudy",
"icon_url":"http://icons.wxug.com/i/c/k/partlycloudy.gif",
"title":"Dienstag",
"fcttext":"Teilweise bedeckt. Höchsttemperatur 50F. Wind aus SW mit 15 bis 25 mph.",
"fcttext_metric":"Teilweise bedeckt. Höchsttemperatur 10C. Wind aus SW mit 25 bis 40 km/h.",
"pop":"10"
"period":3,
"icon":"nt_clear",
"icon_url":"http://icons.wxug.com/i/c/k/nt_clear.gif",
"title":"Dienstag Nacht",
"fcttext":"Meistens klar. Tiefsttemperatur 35F. Wind aus SSW mit 10 bis 20 mph.",
"fcttext_metric":"Meistens klar. Tiefsttemperatur 2C. Wind aus SSW mit 15 bis 30 km/h.",
"pop":"10"
So, I hope, that clears it - have fun! and merry christmas (watching my son playing around with the PS4 and Star Wars Battlefront II)
Thanks, Thomas for this outstanding support.
I will check out your suggestions for my use case.
By the way - I just recognized, that the icon channel just returns the image itself (image item).
So I guess my first try is to extract the name of the icon from the JSON response and generate the link to my local file.
Battlefront II - nice.
My sons are still too young for it though
But it might be a good reason to buy the (someday upcoming) PS5
That was really helpful, Thomas.
Again, thanks for your help.
It took a while, but I figured it out to generate the right icon names out of the json response:
For others, who might struggle with the icon stuff and the German language as well:
API request:
http://api.wunderground.com/api/YOUR_API_KEY_HERE/conditions/forecast10day/lang:DL/q/Germany/Berlin.json
The first icon name you get by JSONPATH like
val String current_tmp = transform("JSONPATH", "$.current_observation.icon", json)
the others by:
val String icon_0_tmp = transform("JSONPATH", "$.forecast.txt_forecast.forecastday.[0]icon", json)
val String icon_1_tmp = transform("JSONPATH", "$.forecast.txt_forecast.forecastday.[2]icon", json)
(forcastday.[1]icon would be the night between day 0 and 2)
I just create the icon name to the local file by:
Weather_Icon_0.postUpdate(Weather_Icon_Path.state+icon_0_tmp+".svg")
(whereas my Icon_Path is http://192.168.178.50:8080/static/weather_icons/white/)
In my weather widget I refer to the icon files by:
<img src="{{itemState('Weather_Icon_0')}}"/>
Hope it helps others.
Hey, that’s great!
But, I would think, there’s already an Icon-channel in the wu-binding?
if not - or just for the sake of learning, here’s a bit more insight in how to organize Data from weather-APIs:
Yes, there is an icon channel, but it’s not the right way for me.
The reason is, that the icon channel returns a hardcoded image (the image itself).
And because I don’t like its look, I have chosen to go with my local ones (svg from here: https://peter.build/weather-underground-icons/)
So I just extract the english name of the weather condition (file) and create a link to the local file.
The only thing I did not solve yet is the english Mon, Tue, …
Maybe I will solve it through the API directly as well…
that looks nice! If there’s no channel for the item name, then that would be the way to go - but then you can easily get all your weather items by the API… or you could file a issue on github to add an simple icon name
I’ve had that problem on a “normal” sitemap and it was causesd by the OS which hadn’t been set to my language.
Thanks for this idea.
I actually checked that already (running openhabian 1.4 with OH 2.2 on a Raspi 3).
On habpanel, I use:
<div ng-init="daysnames={'Sunday': 'Sonntag', 'Monday': 'Montag', 'Tuesday': 'Dienstag', 'Wednesday': 'Mittwoch', 'Thursday': 'Donnerstag', 'Friday': 'Freitag', 'Saturday': 'Samstag'}">
<td>{{daysnames[(itemValue('ObservationTime1') | date:'EEEE')]}}</td>
<td>{{daysnames[(itemValue('ObservationTime2') | date:'EEEE')]}}</td>
</div>
That’s it!
Thanks a lot, Jürgen.
Hi, sorry @NCO i was not online in the last days, but @opus has written the answer…
@NCO: How can i save the icons as svg from https://peter.build/weather-underground-icons/ to my icons folder? Update: I have found the svg on Github…
Don’t worry - Christmas is for spendingtime worhthe family and friends
So you found the icons? Great. I really like them.
Which weather data provider do you choose? ForecastIo or Openweathermap?
