To get modal dialogs, ui-bootstrap’s $uibModal service would have to be injected into the controller bound to the template (i.e. some Javascript code), and since you’re currently limited to editing the template and can’t modify the controller, you can’t do this.
Just wondering if there is currently a way to display a web page using the template widget? For example I have some emoncms energy dashboards which I would like to embed.
Is it possible to change words to images? I’m trying to make a weather forecast, but a cloud is a lot nicer that the word: cloudy. I’m also strugeling with a good layout (the first part can be 1
instead of 2…)
The above image is the thing i have, the bottom is what i want:
Just FYI: I’m working on weather widget in my spare time Weather forecast is also on my roadmap. Let me know in the issue’s comments section what features you’d like to see there.
This is probably a silly question, but angular is totally new to me. Is there a way of using ng-repeat with the results of an itemValue? ie I have a string item that I want to populate with a JSON object that I can then use to build a table of data in the template widget.
I have tried the following but it didn’t work, I also tried with itemValue directly in the ng-repeat line but that didn’t work either.
Thanks ysc, I generally would use separate items. But in this particular case I really just want to display some additional information on my Dashboards around the house (recently downloaded items) and I don’t know how long the list is on any given day, it could be 1 item or 10 so my thinking was to just push it to a string item as JSON and then use the template widget to format it.
i would like to have the possibility to style it my way … fixed y-axis my be you may provide a function to retrieve the data series and an user may have the possibility to show different series with different layouts, temeratures, power etc…
i know you can set an item value (that isn’t bound to external data feed) with a slider because i tried it, can someone please write us a template with text field that edit items (numbers and strings)and solve the dilemma of Basic & Classic UI ?
i just suck at web stuff, i don’t know what kind of code i can write in a template / widget to start with …
iḿ still thinking about top have my own chart widget, or at least to play around with.
can you give me a hint as startpoint ? what can be used in habpanel from angular framework ? is it possible to include addional functions in an widget ?
i tried:
it does not work, where do i have to place the files ?
