The site_id is a numeric number.
If you run the curl command I posted, it will show you the site’s associated with your account.
I’ll try and work on the code today to let you leave site_id blank.
https://smedley.id.au/tmp/org.openhab.binding.teslapowerwallcontrol-3.3.0-SNAPSHOT.jar is refreshed - it should be possible to leave the Site ID blank now - it works for me at least ![]()
Works for me too ![]()
I have to find out why the items in (local) teslapowerwall show power in units of kW and the (cloud based) teslapowerwallcontrol show them in W.
Woohoo! I think the difference just comes down to my mood when I coded it. I can made the cloud version do kW too.
I’m nearly there with the ability to change the reserve, for some reason, I’m getting:
2022-02-04 19:12:07.518 [DEBUG] [nternal.TeslaPowerwallControlHandler] - Setting reserve to: 12
2022-02-04 19:12:07.520 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - payload = {"backup_reserve_percent":'12'}
2022-02-04 19:12:07.521 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - Calling url: https://owner-api.teslamotors.com/api/1/energy_sites/140608504302/backup
2022-02-04 19:12:07.707 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - response to reserve change = {"error":"invalid JSON: unexpected character (after backup_reserve_percent) at line 1, column 27 [parse.c:769] in '{\"backup_reserve_percent\":'12'}"}
ie my nicely formatted JSON is getting \ added to it and an extra "} and I have no idea why.
Soooo close!
double post ? double answer:
You get back \ and extra leading and trailing {} to make the server return JSON comatible.
Did you try to replace ’ by " in your server request ‘12’ => “12” ?
The Tesla server doesn’t like double quotes - only single quotes…
Actually, it can handle no quotes as well…
so:
String payload = "{\"backup_reserve_percent\":" + newreserve + "}";
results in:
2022-02-05 07:26:01.342 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - payload = {"backup_reserve_percent":9}
2022-02-05 07:26:01.343 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - Calling url: https://owner-api.teslamotors.com/api/1/energy_sites/140608504xxx/backup
2022-02-05 07:26:01.675 [DEBUG] [rnal.TeslaPowerwallControlWebTargets] - response to reserve change = {"response":{"code":201,"message":"Updated"}}
Seems I just needed a night to sleep on it ![]()
Apologies for any inconvenience, but I’ve renamed the binding to TeslaPowerwallCloud to make it clearer what the differences are to my TeslaPowerwall binding. I may also consider renaming TeslaPowerwall to TeslaPowerwallLocal in the future.
New download link is https://smedley.id.au/tmp/org.openhab.binding.teslapowerwallcloud-3.3.0-SNAPSHOT.jar
I’ll commit this change to my github shortly, and will aim to support toggling Storm Mode, and changing Operating mode before the end of this weekend.
Update:
I got distracted today, and added several mode channels instead of adding support for toggling operating mode and storm mode.
New channels:
Update 2:
I’ve worked out how to (via curl) change Operating Mode and Storm mode, so this should be trivial to support. Will aim to implement this on Sunday.
Update 3:
Looks like Island mode can be used to go off grid - so I’ll need to change it from read-only and work out how to use it.
New jar is working here, too. Units are still W.
…is there any example how to integrate/ startup? Using VSC and avoid the OH frontend
I’ll look at changing units to kW in the morning my time.
.jar refreshed - units now in kW
.jar updated again - toggling Storm Watch mode and Changing Operating Mode should be working now.
Still TODO:
Units now in kW ![]()
Thanks for confirming!
Where can i find the token. i do not have an android device but an ios device.
I don’t have an IOS device but I believe Auth app for Tesla App - App Store should do the trick
Hello
yes it seemed to work, thank you.
But i had no success with the CURL command you provided.
I left it empty and the thing goes online.
I have to test creating items yet.
I got it working and implemented items for the power as well as the SOC.
The soc does not give a correct value.
Currently the PW is charged 6 % according to the app and the channel returns 0.8382.
how do i interpret this?
i thought 1 = 100 %
That’s strange. The percent-charged channel matches the app here, and has done for the two months since I created the binding. Here it returns the actual percentage - 98 for me right now ![]()
Ok.
It’s currently at 100 %, in reality the pw2 is at 22 % soc. but i recognized the Thing got offline reporting a communication error with the api:
TeslaPowerwallCloudcontroller returned error while invoking https://owner-api.teslamotors.com/api/1/products
i checked the token in the app and it is still the same.
strange …
I do need to try and improve the error reporting. Having said that, the only time I got an offline error report was when my token expired. I did see this (https://forums.whirlpool.net.au/go?https%3A%2F%2Fgithub.com%2Ftimdorr%2Ftesla-api%2Fissues%2F548) yesterday - it’s not clear to me (yet) if this affects the binding. I haven’t figured out how to check how long until the token expires using the Tesla API.
Edit: I’m wondering if the token you generated is one of the new ones that only lasts for 8 hours?
