I agree, Grid Energy Imported is ~2,7% higher than the value shown by the app.
Home Energy Imported was mentioned above, Home Energy exported is 0 kWh in my case.
Battery Energy Imported is about 10% higher than the value of the charged energy out of the solar panels: 10.9 MWh, app states 9,7 MWh
Might be that Battery Energy Imported takes the usage of the PW (Gateway and storage unit) itself into account too, but the app doesn’t account for this. That’s why you get effifcencies of about 90% in the App and 80% with the values from the api.
Grid Energy Exported is about the same as the value in the app shown on the upper right if you select the grid at the bottom: 18.6 MWh vs 18.4 MWh in my PW.
I corrected my post… Home Energy Exported is also 0 kWh here.
Interesting observations Christian.
For me: Grid Energy Exported is 2.2 MWh from the api, 1.5 MWh in the app. Battery Energy Imported - I can’t really tell as my solar and pw were installed years apart.
Oddly my battery reserve is reported as 0 in the thing/channel, but accessing the api directly from the pw gives the correct value. If I had to guess it feels like a format issue ?
My understanding is that to help them with warranty, new batteries have capacity above 13500. Net Zero (phone app) states the degradation is based on 13500, and reports 0% where the current capacity is above this.
I can also confirm that my battery was replaced based on the reported ‘full energy’ being < 70% of 13500.
When I get a chance I’ll tweak things so that degradation is 0 where capacity is above 13500.
Edit: Committed this change and updated the link. Also clarified in the channel description that degradation is based on full capacity of 13.5kW.
My turn this time for a slow reply. Try deleting the item and creating a new one. Perhaps the item inherited the previous (wrong) state description. I created a new thing/item on a fresh install and it looks good here.
has this become the teslapowerwall binding now ?
Asking because the docs at TeslaPowerwall - Bindings | openHAB are totally missing information about the battery control stuff.
