narf27
(Peter)
September 18, 2020, 12:01pm
21
like this?
#!/usr/bin/env bash -x
BASEDIR=/opt/openhabian
CONFIGFILE=/etc/openhabian.conf
source $CONFIGFILE
source ${BASEDIR}/functions/helpers.bash
source ${BASEDIR}/functions/backup.bash
mirror_SD "$@"
with “-x”:
[13:59:19] root@ohab2:/media/influxdbstick/data# /usr/local/sbin/mirror_SD "raw" /dev/sda
/usr/bin/env: ‘bash -x’: No such file or directory
/usr/bin/env: use -[v]S to pass options in shebang lines
withoud “-x”
[13:32:08] root@ohab2:/media/influxdbstick/data# /usr/local/sbin/mirror_SD "raw" /dev/sda
blockdev: cannot open : No such file or directory
FAILED (bad destination)
mstormi
(Markus Storm)
September 18, 2020, 12:02pm
22
then use “set -x” as the 2nd line
narf27
(Peter)
September 18, 2020, 12:43pm
23
okay:
[14:42:46] root@ohab2:/media/influxdbstick/data# /usr/local/sbin/mirror_SD "raw" /dev/sda
+ BASEDIR=/opt/openhabian
+ CONFIGFILE=/etc/openhabian.conf
+ source /etc/openhabian.conf
++ hostname=openhab
++ username=openhabian
++ timeserver=0.pool.ntp.org
++ locales='en_US.UTF-8 de_DE.UTF-8'
++ system_default_locale=en_US.UTF-8
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ repositoryurl=https://github.com/openhab/openhabian
++ clonebranch=master
++ debugmode=maximum
++ java_opt=Zulu8-32
+ source /opt/openhabian/functions/helpers.bash
++ ESC='\033['
++ COL_DEF='\033[39;49;00m'
++ COL_RED='\033[31;01m'
++ COL_GREEN='\033[32;01m'
++ COL_YELLOW='\033[33;01m'
++ COL_BLUE='\033[34;01m'
++ COL_MAGENTA='\033[35;01m'
++ COL_CYAN='\033[36;01m'
++ COL_LGRAY='\033[37;01m'
++ COL_DGRAY='\033[90;01m'
++ export COL_DEF COL_RED COL_GREEN COL_YELLOW COL_BLUE COL_MAGENTA COL_CYAN COL_LGRAY COL_DGRAY
+ source /opt/openhabian/functions/backup.bash
+ mirror_SD raw /dev/sda
+ local src=/dev/mmcblk0
+ local dest
+ local start
+ local syncMount=/storage/syncmount
+ [[ -n '' ]]
+ dest=
+ [[ /dev/mmcblk0 == '' ]]
++ blockdev --getsize64 ''
+ [[ -n '' ]]
+ echo 'FAILED (bad destination)'
+ return 1
mstormi
(Markus Storm)
September 18, 2020, 2:38pm
24
Fix L361 in backup.bash to read
dest="${2:-${backupdrive}}"
and in L393 change 2 to 3
narf27
(Peter)
September 18, 2020, 7:04pm
25
new error:
[20:26:41] root@ohab2:/media/influxdbstick/data# /usr/local/sbin/mirror_SD "raw" /dev/sda
++ hostname=openhab
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ ESC='\033['
+ local dest
+ local start
+ [[ -n '' ]]
+ dest=/dev/sda
+ [[ /dev/mmcblk0 == \/\d\e\v\/\s\d\a ]]
++ blockdev --getsize64 /dev/sda
+ [[ -n 31914983424 ]]
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ [[ raw == \r\a\w ]]
+ echo 'Creating a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card'
+ cond_redirect dd if=/dev/mmcblk0 bs=1M of=/dev/sda
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ dd if=/dev/mmcblk0 bs=1M of=/dev/sda \033[39;49;00m'
+ dd if=/dev/mmcblk0 bs=1M of=/dev/sda
15193+1 records in
15193+1 records out
15931539456 bytes (16 GB, 15 GiB) copied, 980.984 s, 16.2 MB/s
+ return 0
+ cond_redirect fsck -y -t vfat /dev/sda1
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ fsck -y -t vfat /dev/sda1 \033[39;49;00m'
+ fsck -y -t vfat /dev/sda1
fsck from util-linux 2.33.1
fsck.fat 4.1 (2017-01-24)
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Automatically removing dirty bit.
Performing changes.
/dev/sda1: 247 files, 110143/516190 clusters
+ return 1
+ echo 'FAILED (fsck /boot)'
FAILED (fsck /boot)
+ return 1
mstormi
(Markus Storm)
September 18, 2020, 7:18pm
26
well not exactly an error as it corrected your filesystem.
Will change that nonetheless.
get & replace latest backup.bash
narf27
(Peter)
September 18, 2020, 8:32pm
27
same:
[20:43:13] root@ohab2:/media/influxdbstick/data# wget https://raw.githubusercontent.com/openhab/openhabian/master/functions/backup.bash
backup.bash 100%[========================================================================================================================================>] 26.62K --.-KB/s in 0.02s
2020-09-18 21:21:24 (1.62 MB/s) - ‘backup.bash’ saved [27264/27264]
[21:21:24] root@ohab2:/media/influxdbstick/data# cp backup.bash /opt/openhabian/functions/backup.bash
[21:21:41] root@ohab2:/media/influxdbstick/data# /usr/local/sbin/mirror_SD "raw" /dev/sda
++ hostname=openhab
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ ESC='\033['
+ local dest
+ local start
+ [[ -n '' ]]
+ dest=/dev/sda
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ [[ -n '' ]]
15193+1 records in
15193+1 records out
15931539456 bytes (16 GB, 15 GiB) copied, 989.669 s, 16.1 MB/s
+ return 0
+ [[ -n '' ]]
Performing changes.
+ return 1
+ echo 'FAILED (dirty fsck /dev/sda)'
+ return 1
mstormi
(Markus Storm)
September 18, 2020, 9:35pm
28
download & try again please
narf27
(Peter)
September 18, 2020, 10:20pm
29
i still get the error regarding the “Dirty bit”:
[00:00:40] root@ohab2:/home/openhabian# /usr/local/sbin/mirror_SD "raw" /dev/sda
++ hostname=openhab
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ ESC='\033['
+ local dest
+ local start
+ local failed=no
+ [[ -n '' ]]
+ dest=/dev/sda
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ [[ -n '' ]]
15193+1 records in
15193+1 records out
15931539456 bytes (16 GB, 15 GiB) copied, 1001.76 s, 15.9 MB/s
+ return 0
+ [[ -n '' ]]
Performing changes.
+ return 1
+ echo 'FAILED (dirty fsck /dev/sda1) '
+ failed=yes
+ cond_redirect fsck -y -t ext4 /dev/sda2
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ fsck -y -t ext4 /dev/sda2 \033[39;49;00m'
+ fsck -y -t ext4 /dev/sda2
e2fsck 1.44.5 (15-Dec-2018)
rootfs: recovering journal
Clearing orphaned inode 24293 (uid=0, gid=0, mode=0100600, size=0)
Setting free inodes count to 864023 (was 864057)
Setting free blocks count to 2375959 (was 2376094)
rootfs: clean, 71977/936000 files, 1447017/3822976 blocks
+ return 0
+ [[ yes == \n\o ]]
+ return 1
mstormi
(Markus Storm)
September 18, 2020, 10:26pm
30
that is sort of correct as the filesystem indeed was not unmounted.
Maybe I should not output that as FAILED.
I made one last change but it’s only the output that changed not the logic
You can test again but don’t have to.
narf27
(Peter)
September 19, 2020, 7:08am
31
ok, dirty bit is “okay” now
[08:37:26] root@ohab2:/home/openhabian# /usr/local/sbin/mirror_SD "raw" /dev/sda
++ hostname=openhab
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ ESC='\033['
+ local dest
+ local start
+ local dirty=no
+ [[ -n '' ]]
+ dest=/dev/sda
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ [[ -n '' ]]
15193+1 records in
15193+1 records out
15931539456 bytes (16 GB, 15 GiB) copied, 988.415 s, 16.1 MB/s
+ return 0
+ [[ -n '' ]]
Performing changes.
+ return 1
+ echo 'OK (dirty bit on fsck /dev/sda1 is normal) '
+ dirty=yes
+ [[ -n '' ]]
Setting free inodes count to 864023 (was 864056)
Setting free blocks count to 2375956 (was 2376094)
rootfs: clean, 71977/936000 files, 1447020/3822976 blocks
+ return 0
+ [[ yes == \n\o ]]
+ return 1
just to be sure: my sd card is ok? or does this (previous) error indicate a problem?
mstormi
(Markus Storm)
September 19, 2020, 7:28am
32
yes it should be fine. All errors were either due to the code or because the filesystem was not unmounted when we checked it. Because the source (the internal SD) was not unmounted when we copied it.
I think it works fine now. Thanks for your testing help.
narf27
(Peter)
September 19, 2020, 8:34am
33
atm there’s nothing that would inform a “normal” would if something went wrong, is there?
thinking about alle the things i had trouble with (obviously also because of my own fault): zram-config, amanda, auto-backup… well, there enough things that could go wrong.
(all this things will still be relevant to oh3, right?)
have a nice day!
mstormi
(Markus Storm)
September 19, 2020, 9:33am
34
There is, you should see a FAILED line in unattended install. It’s logged in /boot/first-boot.log.
narf27
(Peter)
September 19, 2020, 10:09am
35
i’m not sure if unexperienced users would set already set this options in unattended install.
some people might need to get a bigger card for backup before setting up auto-backup f.e..
but as this i running now it shouldn’t be a problem anymore!
mstormi
(Markus Storm)
September 19, 2020, 10:11am
36
these can use interactive setup. I don’t get your point?
narf27
(Peter)
September 21, 2020, 11:17am
37
my auto-backup was not working after the (successful) setup, but i only discovered this because of your help.
a “normal” user might not look into logs to check if the script worked as expected.
another point: i ran openhabian-config and this message pops up:
## August 29, 2020
## Auto-backup (BETA)
openHABian can automatically take daily syncs of your internal SD card to
another card in an external port. This allows for fast swapping of cards
to reduce impact of a failed SD card.
The remaining space on the external device will also be used to setup
openHABian's Amanda backup system.
i’ve i’m not mistaken this message would only pop up only after a successful openhabian-config, right?
if that were the case the unattended installation already happened. if a user hadn’t previously opted for the auto-backup installation, the following installation via openhabian-config wouldn’t setup amanda. so the last sentence might not be 100% true.
obviously it becomes clearer when the user checks the openhabian-docs
mstormi
(Markus Storm)
September 21, 2020, 11:34am
38
“bc”? what are you trying to tell ?
What sort of problem did you hit ?
well you cannot expect to get the full story in an announcement summary, can you
narf27
(Peter)
September 21, 2020, 11:43am
39
mstormi:
“bc” > “because” - corrected it in post.
mstormi:
the problems we discussed in this thread (until your modifications solved the problem!).
mstormi:
absolutely
but maybe
The remaining space on the external device can also be used to setup openHABian’s Amanda backup system.
but that’s really just a minor detail and it’s all the same for me. just some input
mstormi
(Markus Storm)
September 21, 2020, 8:10pm
40
Run blkid and compare UUIDs of internal and external SD.
If they’re equal, update openhabian to master branch and run dd sync via menu 54.
