finally i found some the time to re-setup sd-mirroring…
++ whiptail --title 'Setup SD mirroring' --cancel-button Cancel --ok-button Select --menu '\nSelect USB device to copy t he internal SD card data to' 12 76 0 sda 29.7G sdb 1006M
+ retval=sda
+ [[ -z sda ]]
+ dest=/dev/sda
++ blockdev --getsize64 /dev/sda
+ [[ ! -n 31914983424 ]]
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ infoText='DANGEROUS OPERATION, USE WITH PRECAUTION!\n\nThis will *copy* your system root from your SD card to a USB at tached card writer device. Are you sure /dev/sda is an SD card writer device equipped with a dispensible SD card? Are yo u sure, this will destroy all data on that card and you want to proceed writing to this device?'
++ blockdev --getsize64 /dev/mmcblk0
+ srcSize=15931539456
+ minSize=30269924966
+ destSize=31914983424
+ [[ 31914983424 -lt 30269924966 ]]
+ [[ -n 1 ]]
+ whiptail --title 'Copy internal SD to /dev/sda' --yes-button Continue --no-button Back --yesno 'DANGEROUS OPERATION, U SE WITH PRECAUTION!\n\nThis will *copy* your system root from your SD card to a USB attached card writer device. Are you sure /dev/sda is an SD card writer device equipped with a dispensible SD card? Are you sure, this will destroy all data on that card and you want to proceed writing to this device?' 12 116
++ basename /storage
+ mountUnit=storage.mount
+ systemctl stop storage.mount
++ fdisk -l /dev/mmcblk0
++ head -1
++ cut '-d ' -f7
+ start=31116288
+ (( destSize-=start ))
+ sfdisk -d /dev/mmcblk0
+ sfdisk --force /dev/sda
+ echo '/dev/mmcblk0p3 : start=31116288,size=31883867136, type=83'
Checking that no-one is using this disk right now ... OK
Disk /dev/sda: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Disk model: Card Reader
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6afa72a2
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 31116287 30583808 14.6G 83 Linux
/dev/sda3 31116288 62333951 31217664 14.9G 83 Linux
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0xb5915213.
/dev/sda1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 256 MiB.
Partition #1 contains a vfat signature.
/dev/sda2: Created a new partition 2 of type 'Linux' and of size 14.6 GiB.
Partition #2 contains a ext4 signature.
/dev/sda3: Created a new partition 3 of type 'Linux' and of size 14.9 GiB.
Partition #3 contains a ext4 signature.
/dev/sda4: Done.
New situation:
Disklabel type: dos
Disk identifier: 0xb5915213
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
+ partprobe
+ cond_redirect mke2fs -F -t ext4 /dev/sda3
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ mke2fs -F -t ext4 /dev/sda3 \033[39;49;00m'
+ mke2fs -F -t ext4 /dev/sda3
mke2fs 1.44.5 (15-Dec-2018)
/dev/sda3 contains a ext4 file system
last mounted on Sun Oct 4 20:38:18 2020
Creating filesystem with 3902208 4k blocks and 977280 inodes
Filesystem UUID: 8d6f13fa-3d20-473e-956d-def41210f882
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
+ return 0
+ mirror_SD raw /dev/sda
+ local src=/dev/mmcblk0
+ local dest=/dev/sda
+ local start
+ local storageDir=/storage
+ local syncMount=/storage/syncmount
+ local dirty=no
+ local 'dumpInfoText=For your information as the operator of this openHABian system:\nA timed background job to run sem iannually has just created a full raw device copy of your RPI'\''s internal SD card.\nOnly partitions to contain openHAB ian (/boot and / partitions 1 & 2) were copied.'
+ local partUUID
+ [[ /dev/mmcblk0 == \/\d\e\v\/\s\d\a ]]
+ [[ -n 31914983424 ]]
++ mount
++ grep /dev/sda
+ [[ -n '' ]]
+ [[ ! -d /storage/syncmount ]]
+ [[ raw == \r\a\w ]]
+ for i in 1 2
++ blockdev --getsize64 /dev/mmcblk0p1
+ srcSize=268435456
++ blockdev --getsize64 /dev/sda1
+ destSize=268435456
+ [[ 268435456 -lt 268435456 ]]
+ for i in 1 2
++ blockdev --getsize64 /dev/mmcblk0p2
+ srcSize=15658909696
++ blockdev --getsize64 /dev/sda2
+ destSize=15658909696
+ [[ 15658909696 -lt 15658909696 ]]
+ echo 'Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card'
+ cond_redirect dd if=/dev/mmcblk0p1 bs=1M of=/dev/sda1 status=progress
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ dd if=/dev/mmcblk0p1 bs=1M of=/dev/sda1 status=progress \033[39;49;00m'
+ dd if=/dev/mmcblk0p1 bs=1M of=/dev/sda1 status=progress
268435456 bytes (268 MB, 256 MiB) copied, 12 s, 22.4 MB/s
256+0 records in
256+0 records out
268435456 bytes (268 MB, 256 MiB) copied, 18.3414 s, 14.6 MB/s
+ return 0
+ cond_redirect dd if=/dev/mmcblk0p2 bs=1M of=/dev/sda2 status=progress
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ dd if=/dev/mmcblk0p2 bs=1M of=/dev/sda2 status=progress \033[39;49;00m'
+ dd if=/dev/mmcblk0p2 bs=1M of=/dev/sda2 status=progress
15654191104 bytes (16 GB, 15 GiB) copied, 969 s, 16.2 MB/s
14933+1 records in
14933+1 records out
15658909696 bytes (16 GB, 15 GiB) copied, 978.411 s, 16.0 MB/s
+ return 0
++ blkid /dev/mmcblk0p2
++ sed -n 's|^.*PARTUUID="\(\S\+\)".*|\1|p'
++ sed -e s/-02//g
+ origPartUUID=d0c18a5b
++ yes
++ cond_redirect set-partuuid /dev/sda2 random
++ [[ -n '' ]]
++ echo -e '\n\033[90;01m$ set-partuuid /dev/sda2 random \033[39;49;00m'
++ set-partuuid /dev/sda2 random
++ awk '/^PARTUUID/ { print substr($7,1,length($7) - 3) }'
++ return 0
+ partUUID=67d80d57
+ cond_redirect tune2fs /dev/sda2 -U random
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ tune2fs /dev/sda2 -U random \033[39;49;00m'
+ tune2fs /dev/sda2 -U random
tune2fs 1.44.5 (15-Dec-2018)
+ return 0
+ mount /dev/sda1 /storage/syncmount
+ sed -i 's|d0c18a5b|67d80d57|g' /storage/syncmount/cmdline.txt
+ umount /storage/syncmount
+ mount /dev/sda2 /storage/syncmount
+ sed -i 's|d0c18a5b|67d80d57|g' /storage/syncmount/etc/fstab
+ sed -i 's|^What=.*|What=/dev/mmcblk0p3|g' /storage/syncmount/etc/systemd/system//storage.mount
+ cond_redirect fsck -y -t ext4 /dev/sda2
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ fsck -y -t ext4 /dev/sda2 \033[39;49;00m'
+ fsck -y -t ext4 /dev/sda2
fsck from util-linux 2.33.1
e2fsck 1.44.5 (15-Dec-2018)
rootfs: clean, 74101/936000 files, 1470734/3822976 blocks
+ return 0
+ [[ no == \n\o ]]
+ echo OK
OK
+ echo -e 'For your information as the operator of this openHABian system:\nA timed background job to run semiannually h as just created a full raw device copy of your RPI'\''s internal SD card.\nOnly partitions to contain openHABian (/boot and / partitions 1 & 2) were copied.'
+ mail -s 'SD card raw copy dump' ''
mail: No recipients specified
+ return 0
+ sed -e 's|%DEVICE|/dev/sda3|g' -e 's|%STORAGE|/storage|g' /opt/openhabian/includes/storage.mount
+ cond_redirect systemctl enable --now storage.mount
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl enable --now storage.mount \033[39;49;00m'
+ systemctl enable --now storage.mount
+ return 0
+ sed -e 's|%DEST|/dev/sda|g' /opt/openhabian/includes/sdrawcopy.service_template
+ sed -e 's|%DEST|/dev/sda|g' /opt/openhabian/includes/sdrsync.service_template
+ cond_redirect cp /opt/openhabian/includes/sdrawcopy.timer /opt/openhabian/includes/sdrsync.timer /etc/systemd/system//
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ cp /opt/openhabian/includes/sdrawcopy.timer /opt/openhabian/includes/sdrsync.timer /etc/system d/system// \033[39;49;00m'
$ cp /opt/openhabian/includes/sdrawcopy.timer /opt/openhabian/includes/sdrsync.timer /etc/systemd/system//
+ cp /opt/openhabian/includes/sdrawcopy.timer /opt/openhabian/includes/sdrsync.timer /etc/systemd/system//
+ return 0
+ echo OK
OK
+ cond_redirect install -m 755 /opt/openhabian/includes/mirror_SD /usr/local/sbin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ install -m 755 /opt/openhabian/includes/mirror_SD /usr/local/sbin \033[39;49;00m'
+ install -m 755 /opt/openhabian/includes/mirror_SD /usr/local/sbin
+ return 0
+ cond_redirect systemctl -q daemon-reload
+ cond_redirect systemctl enable --now sdrawcopy.timer sdrsync.timer
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl enable --now sdrawcopy.timer sdrsync.timer \033[39;49;00m'
+ systemctl enable --now sdrawcopy.timer sdrsync.timer
+ return 0
+ echo OK
OK
+ [[ -z 1 ]]
+ '[' 0 -ne 0 ']'
+ true
+ show_main_menu
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=master
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=v1.6
++++ git -C /opt/openhabian log --oneline
++++ wc -l
+++ revCount=879
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=c25239d
+++ echo '[master]v1.6-879(c25239d)'
++ whiptail --title 'Welcome to the openHABian Configuration Tool [master]v1.6-879(c25239d)' --menu 'Setup Options' 18 1 16 11 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and thi s tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' ' Upgrade all installed software packages (incl. openHAB) to their latest version' '03 | openHAB Stable' 'Install or upgra de to the latest stable release of openHAB 2' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basi c openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Sett ings' 'A range of system and hardware related configuration steps ►' '40 | openHAB related' 'Switch the installed openHA B version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pizero
+ [[ '' == \p\i\0 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]09[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pizerow
+ [[ '' == \p\i\0\w ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[cC][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pione
+ [[ '' == \p\i\1 ]]
+ grep -q '^Revision\s*:\s*00[0-9a-fA-F][0-9a-fA-F]$' /proc/cpuinfo
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[0-36][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmone
+ [[ '' == \c\m\1 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]06[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pitwo
+ [[ '' == \p\i\2 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]04[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pithree
+ [[ '' == \p\i\3 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]08[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmthree
+ [[ '' == \c\m\3 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[aA][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pithreeplus
+ [[ '' == \p\i\3\+ ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[dDeE][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmthreeplus
+ [[ '' == \c\m\3\+ ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]10[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pizero
+ return 1
+ is_pizerow
+ return 1
+ is_pione
+ return 1
+ is_cmone
+ return 1
+ is_pitwo
+ return 1
+ is_pithree
+ return 1
+ is_cmthree
+ return 1
+ is_pithreeplus
+ return 1
+ is_cmthreeplus
+ return 1
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pizero
+ return 1
+ is_pizerow
+ return 1
+ is_pione
+ return 1
+ is_cmone
+ return 1
+ is_pitwo
+ return 1
+ is_pithree
+ return 1
+ is_cmthree
+ return 1
+ is_pithreeplus
+ return 1
+ is_cmthreeplus
+ return 1
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ grep -w openhabian /etc/shadow
++ cut -d: -f2
+ originalPassword='$6$Oa2jE7q9LCf2pwQg$CLetQr8dlemHVGxr9.wbHNvBb6ka.UdH.8usMFy8XpTqxGP15mVAkART3WMCVWhNCWoGU7kJFpwyuyp1 EpmpQ1'
++ echo '$6$Oa2jE7q9LCf2pwQg$CLetQr8dlemHVGxr9.wbHNvBb6ka.UdH.8usMFy8XpTqxGP15mVAkART3WMCVWhNCWoGU7kJFpwyuyp1EpmpQ1'
++ cut '-d$' -f2
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!'
++ cut '-d$' -f3
+ salt=Oa2jE7q9LCf2pwQg
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='$6$Oa2jE7q9LCf2pwQg$9HTAmBlN7dLelML.38m4zn0c87LbiBI6xQjDcD5xAeCDQQuMxeD6a3ueqs8x2w13Kogedhqd.gVsgbQ 96lNM71'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-10-04_21:21:26_CEST [openHABian] Checking for default openHABian username:password combination... '
2020-10-04_21:21:26_CEST [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabi an
+ [[ -n 1000 ]]
+ [[ $6$Oa2jE7q9LCf2pwQg$9HTAmBlN7dLelML.38m4zn0c87LbiBI6xQjDcD5xAeCDQQuMxeD6a3ueqs8x2w13Kogedhqd.gVsgbQ96lNM71 == \$\6\ $\O\a\2\j\E\7\q\9\L\C\f\2\p\w\Q\g\$\C\L\e\t\Q\r\8\d\l\e\m\H\V\G\x\r\9\.\w\b\H\N\v\B\b\6\k\a\.\U\d\H\.\8\u\s\M\F\y\8\X\p\ T\q\x\G\P\1\5\m\V\A\k\A\R\T\3\W\M\C\V\W\h\N\C\W\o\G\U\7\k\J\F\p\w\y\u\y\p\1\E\p\m\p\Q\1 ]]
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2020-10-04_21:21:26_CEST [openHABian] We hope you got what you came for! See you again soon ;)'
+ cd /home/openhabian
i don’t see any errors, so it should be okay to proceed with amanda, right?
