Nope, plain ARMBIAN:
bhuism@udoo:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.3 (jessie)
Release: 8.3
Codename: jessie
Java:
bhuism@udoo:~$ java -version
java version "1.8.0_71"
Java(TM) SE Runtime Environment (build 1.8.0_71-b15)
Java HotSpot(TM) Client VM (build 25.71-b15, mixed mode)
Looks like the latest version can not find any converts:
(of should I remove and add the things again? then I get “Error loading inbox!” in Habmin2 and “ERROR: 500 - Internal Server Error” in Paper UI)
2016-02-27 14:51:42.714 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:alarm_general, class ALARM
2016-02-27 14:51:42.714 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: No converter for zwave:aeon_zw089_00_000:1530ad9faba:node11:alarm_general, class ALARM
2016-02-27 14:51:42.716 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.718 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.718 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.718 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:alarm_general, class ALARM
2016-02-27 14:51:42.720 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:sensor_power, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.720 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.722 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: No converter for zwave:aeon_zw089_00_000:1530ad9faba:node11:battery-level, class BATTERY
2016-02-27 14:51:42.726 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_relhumidity, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.726 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh, class METER
2016-02-27 14:51:42.726 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_color, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.728 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_ultraviolet, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.728 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_watts, class METER
2016-02-27 14:51:42.728 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_color, class COLOR
2016-02-27 14:51:42.734 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:sensor_power1, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.736 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_color, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.736 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_temperature, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.736 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer1, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.736 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_color, class BASIC
2016-02-27 14:51:42.737 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer1, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.737 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_temperature, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.738 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh1, class METER
2016-02-27 14:51:42.738 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter for zwave:aeon_zw098_00_000:1530ad9faba:node8:color_temperature, class COLOR
2016-02-27 14:51:42.738 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_luminance, class SENSOR_MULTILEVEL
2016-02-27 14:51:42.739 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_watts1, class METER
2016-02-27 14:51:42.747 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer2, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.747 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: No converter for zwave:aeon_zw089_00_000:1530ad9faba:node11:sensor_binary, class SENSOR_BINARY
2016-02-27 14:51:42.749 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer2, class SWITCH_MULTILEVEL
2016-02-27 14:51:42.747 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_binary, class SENSOR_BINARY
2016-02-27 14:51:42.774 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary, class SWITCH_BINARY
2016-02-27 14:51:42.774 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary, class SWITCH_BINARY
2016-02-27 14:51:42.777 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary1, class SWITCH_BINARY
2016-02-27 14:51:42.778 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node6:switch_binary, class SWITCH_BINARY
2016-02-27 14:51:42.777 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary1, class SWITCH_BINARY
2016-02-27 14:51:42.782 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node6:switch_binary1, class SWITCH_BINARY
2016-02-27 14:51:42.793 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: No converter for zwave:greenwave_gwpn6_00_000:1530ad9faba:node10:switch_binary, class SWITCH_BINARY
2016-02-27 14:51:42.807 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: No converter for zwave:greenwave_gwpn1_03_000:1530ad9faba:node7:switch_binary, class SWITCH_BINARY
2016-02-27 14:51:53.579 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary
2016-02-27 14:51:54.244 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No converter set for zwave:aeon_zw098_00_000:1530ad9faba:node8:switch_dimmer
2016-02-27 14:51:54.568 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node7:switch_binary
2016-02-27 14:51:56.160 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: No converter set for zwave:greenwave_gwpn6_00_000:1530ad9faba:node10:switch_binary
2016-02-27 14:51:57.563 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:51:57.980 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node6:switch_binary
2016-02-27 14:51:58.100 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node6:switch_binary
2016-02-27 14:51:58.758 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:sensor_power
2016-02-27 14:51:58.809 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh
2016-02-27 14:51:58.861 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh
2016-02-27 14:51:58.908 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer
2016-02-27 14:51:58.961 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh1
2016-02-27 14:51:59.035 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:meter_kwh1
2016-02-27 14:51:59.085 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer1
2016-02-27 14:51:59.211 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:sensor_power1
2016-02-27 14:51:59.261 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer2
2016-02-27 14:52:01.947 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:52:26.358 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:52:28.835 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:53:43.591 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter set for zwave:aeon_zw100_00_000:1530ad9faba:node5:alarm_general
2016-02-27 14:54:46.450 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:54:47.423 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:54:54.000 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:54:56.409 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:54:58.804 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:54:59.671 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node12:switch_binary
2016-02-27 14:55:01.806 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: No converter set for zwave:fibaro_fgd212_00_000:1530ad9faba:node4:switch_dimmer
2016-02-27 14:55:01.859 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary
2016-02-27 14:55:01.874 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node6:switch_binary
2016-02-27 14:55:10.017 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter set for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_relhumidity
2016-02-27 14:55:10.727 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter set for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_relhumidity
2016-02-27 14:55:11.896 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter set for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_relhumidity
2016-02-27 14:55:12.040 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: No converter set for zwave:aeon_zw100_00_000:1530ad9faba:node5:sensor_relhumidity
2016-02-27 14:55:19.923 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary
2016-02-27 14:55:25.715 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary
2016-02-27 14:55:28.052 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: No converter set for zwave:greenwave_gwpn1_03_000:1530ad9faba:node3:switch_binary
On the Aeotec led bulb front some change, but no color:
2016-02-27 15:11:10.934 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_color_temperature' received command 91
2016-02-27 15:11:10.939 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_temperature changed from 0 to 91
2016-02-27 15:11:11.089 [WARN ] [.commandclass.ZWaveColorCommandClass] - Unsupported Command 0x05 for command class COLOR (0x33).
2016-02-27 15:11:11.118 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report WARM_WHITE 91
2016-02-27 15:11:11.118 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_color_temperature' received command 91
2016-02-27 15:11:11.151 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report GREEN 0
2016-02-27 15:11:11.214 [WARN ] [.commandclass.ZWaveColorCommandClass] - Unsupported Command 0x05 for command class COLOR (0x33).
2016-02-27 15:11:11.249 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report RED 0
2016-02-27 15:11:11.298 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report COLD_WHITE 9
2016-02-27 15:11:11.347 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report BLUE 0
2016-02-27 15:11:11.348 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 8: Color report finished {WARM_WHITE=91, GREEN=0, RED=0, COLD_WHITE=9, BLUE=0}
2016-02-27 15:11:11.355 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color changed from 0,0,91 to 0,0,0
2016-02-27 15:11:11.363 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_temperature changed from 91 to 0
2016-02-27 15:11:14.396 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No messages returned from converter
2016-02-27 15:11:14.399 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color' received command 339,69,90
2016-02-27 15:11:14.405 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color changed from 0,0,0 to 339,69,90
2016-02-27 15:11:14.696 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No messages returned from converter
2016-02-27 15:11:14.703 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color changed from 339,69,90 to 354,99,90
2016-02-27 15:11:14.706 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color' received command 354,99,90
2016-02-27 15:11:15.687 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: No messages returned from converter
2016-02-27 15:11:15.691 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color' received command 354,99,100
2016-02-27 15:11:15.698 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_aeon_zw098_00_000_1530ad9faba_node8_color_color changed from 354,99,90 to 354,99,100
